The easiest, fastest, and most powerful solution for running Windows applications on a Mac without rebooting.
Launch Windows Apps from the dock, use OS x gestures in Windows Apps, and copy & paste and drag & drop between Mac and Windows.
It is easy to get all of your files, applications, browser bookmarks and more from your PC to your Mac. Just follow wizards.
Parallels desktop
The easiest, fastest, and most powerful solution for running Windows applications on a Mac without rebooting. -
Mac coolness in Windows Apps
Launch Windows Apps from the dock, use OS x gestures in Windows Apps, and copy & paste and drag & drop between Mac and Windows. -
Easy to get all of your files, applications, browser bookmarks and more
It is easy to get all of your files, applications, browser bookmarks and more from your PC to your Mac. Just follow wizards. -
Powerful performance
Support for 16vCPUs and 64 GB of RAM lets you run even the most demanding applications with ease. It won't slow you down. -
Run any Windows Apps on Mac
Use Internet Explorer, Windows Media Player, Access and 100s of other applications not available on the Mac. -
One click tuning
Automatically tune it for what you'll use it for the most: productivity applications, design, development or games. -
It's not just for Windows
Support for running a wide array of operating systems including OS X Mavericks, Windows 8.1 & 7, Linux and Google Chrome means you can do just about anything on your Mac. -
Ready for OS X Yosemite
It's excited about the upcoming Yosemite release. The engineers are hard at work making sure that the Yosemite coolness to Windows Apps too!
- Parallels Desktop for Mac (v. 10) - box pack - 1 user
- Product Type
- Box pack
- Category
- Utilities - desktop virtualisation
- Version
- 10
- Licence Qty
- 1 user
- Platform
- MacOS
- Localisation
- Europe
- Category
- Product Type
- Box pack
- Version
- 10
- Platform
- MacOS
- Localisation
- Europe
Licencing
- Licence Qty
- 1 user
- Supported OS
- Apple MacOS X 10.7.6 or later, Apple OS X 10.9.4 Mavericks or later, Apple OS X 10.8.5 Mountain Lion or later
- Hardware Requirements
- Core 2 Duo RAM 2 GB - HD 850 MB
