The Panasonic SB-TP100 is a high-quality Home Cinema Speaker System designed to match VIERA TVs. With its pure, clear, vibrant sound and true-to-life ambience, the SB-TP100 delivers an audio performance that further enhances the stunning images offered by high-resolution VIERA TVs.
The SB-TP100's height adjustment function makes it easy to position the speakers for optimal acoustic performance according to TV screen size and setup conditions. The stands can be detached if you want to mount the speakers on a wall.
The centre speaker's four, 5-cm staggered-driven woofers achieve wide directional characteristics, ideal when several people are listening together in the living room. Despite its slim appearance, the subwoofer teams up with the high-power 100-W amplifier to deliver a deep, dynamic bass.
The cabinets of the tower-type front speakers and surround speakers are made of extruded aluminum and feature monocoque construction for high rigidity and high-grade composition. The extruded aluminum speaker stands combine excellent stability and elegance with thin dimensions.
