The DMC-SZ8 is equipped with a 24 mm ultra wide-angle lens with a powerful 12x optical zoom for versatility in your photography. Enjoy taking breathtaking landscapes with the wide-angle and bringing sports, portraits, and wildlife up close with the zoom. All of this is packed within the camera's slim, stylish body.
With a variety of filter effects, the Lumix SZ8's creative control lets you add your artistic and creative expression to photos and videos. Creative Panorama function allows you to create dynamic vertical/horizontal panoramic photos by simply swiveling the camera. The large, bright 3.0-inch 460K-dot LCD delivers high visibility in any lighting condition. This sharp LCD is excellent for both shooting and playing back images.
The SZ8's 16-megapixel sensor delivers crisp, clear, high quality images. Enjoy the freedom to crop a part of a photo you want to enlarge after shooting and still have amazing quality. The SZ8's optical image stabilizer compensates for hand-shake that can cause blurred photos. Even slight movement when uses the camera's powerful zoom is accurately detected and compensated for to produce sharp, clear images.
12x optical zoom in a stylish body
The DMC-SZ8 is equipped with a 24 mm ultra wide-angle lens with a powerful 12x optical zoom for versatility in your photography. Enjoy taking breathtaking landscapes with the wide-angle and bringing sports, portraits, and wildlife up close with the zoom. All of this is packed within the camera's slim, stylish body. -
Easy Wi-Fi connection to your smartphone
You can easily connect the SZ8 to your smartphone/tablet by using the "Panasonic Image App" to scan a QR code displayed on the camera screen. Set-up is extremely easy and is finished within a few seconds. A wireless connection between the camera and the smartphone/tablet allows you to use a variety of Wi-Fi functions, such as remote shooting, instant transfer, and Geotagging. -
Creative filter effects for your photos and videos
With a variety of filter effects, the Lumix SZ8's creative control lets you add your artistic and creative expression to photos and videos. Creative Panorama function allows you to create dynamic vertical/horizontal panoramic photos by simply swiveling the camera. -
3-inch Intelligent LCD
The large, bright 3.0-inch 460K-dot LCD delivers high visibility in any lighting condition. This sharp LCD is excellent for both shooting and playing back images. -
16-megapixel sensor
The SZ8's 16-megapixel sensor delivers crisp, clear, high quality images. Enjoy the freedom to crop a part of a photo you want to enlarge after shooting and still have amazing quality. -
Optical image stabilizer
The SZ8's optical image stabilizer compensates for hand-shake that can cause blurred photos. Even slight movement when uses the camera's powerful zoom is accurately detected and compensated for to produce sharp, clear images. -
HDR (High Dynamic Range)
With the HDR (High Dynamic Range) mode, the camera takes several photos consecutively at different exposure levels to make a single composite picture without whiteout (over-exposure) or blackout (under-exposure) even in difficult lighting conditions. Enjoy rich, brilliant color and details with HDR photography. -
Remote shooting/remote view
With the powerful "Panasonic Image App", remote shooting gives you extra control of your photos. Simply place the SZ8 at a shooting location, walk away from it, and what the camera is seeing is displayed on your Wi-Fi compatible smartphone/tablet. You'll have the ability to zoom, set the focus, release the shutter, and change several recording settings such as exposure compensation remotely from your smartphone/tablet. -
On the go easy sharing with Wi-Fi
Instantly upload and share your pictures on SNS using the easy to use "Panasonic Image App" on your Wi-Fi compatible smartphone/tablet. The photo collage function in the app, lets you combine several images into a single picture and then share it with family and friends. -
Wirelessly transfers photos
The instant transfer function gives you the ability to transfer your photo data to a designated electronic device automatically whenever the shutter is released. In playback mode, you can also touch the photo displayed on the camera to transfer it directly to a smartphone/tablet right on the spot. -
Auto transfer
With auto transfer, images are transferred from your camera to a computer or other device while charging the battery with a wireless access point. -
HD video recording
The DMC-SZ8 records dynamic HD videos in 1280 x 720p. Start recording videos quickly and easily by simply pressing the motion picture button on top of the camera. You can conveniently switch between shooting photos and videos instantly. -
iA (Intelligent Auto) mode
In the iA (Intelligent Auto) mode, the camera does all the work, leaving you free to compose your shot and capture the moment. Simply aim, press, and shoot. iA mode integrates the optical image stabilizer, face detection, intelligent scene selector, and intelligent exposure resulting in breathtaking photos with ease of operation.
- Panasonic Lumix DMC-SZ8 - digital camera
- Product Type
- Digital camera - 720p - compact
- Memory Card Slot
- SD card
- Wireless Interface
- Wi-Fi
- Sensor Resolution
- 16.0 Megapixel
- Max Video Resolution
- 1280 x 720
- Lens System
- Zoom lens - 12x zoom - 4.3 - 51.6 mm - f/3.1-6.3
- Focus Adjustment
- Automatic
- Min Focus Distance
- 3 cm
- Digital Zoom
- 4x
- Image Stabiliser
- Optical
- Camera Flash
- Built-in flash
- Display
- LCD display - 3"
- Supported Battery
- Li-ion rechargeable battery - 690 mAh (included)
- Interface
- Composite video/audio, USB 2.0
- Black
- 9.98 cm x 2.65 cm x 6.04 cm
- 144 g
- Product Type
- Enclosure Colour
- Black
- Sensor Resolution
- 16.0 Megapixel
- Optical Sensor Type
- CCD
- Total Pixels
- 16,600,000 pixels
- Effective Sensor Resolution
- 16,000,000 pixels
- Optical Sensor Size
- 1/2.33"
- ISO (Max)
- 6400
- Optical Zoom
- 12x
- Digital Zoom
- 4x
- Image Stabiliser
- Optical
- Built-in Optical Image Stabiliser
- Face Detection
- Print Standard
- Exif Print support, PictBridge support
- Auto Focus
- TTL contrast detection
- Auto Focus Points (Zones) Qty
- 9
- AE/AF Control
- Face-priority AF
- Face Detection
- Face Recognition
- Digital Video Format
- MJPEG
- Image Recording Format
- JPEG
- 1280 x 720
- Interface
- Composite video/audio, USB 2.0, IEEE 802.11b/g/n
- Connectivity Features
- Remote control via mobile devices, remote live view
Exposure & White Balance
- Light Sensitivity
- ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO auto, ISO auto (1600-6400)
- Exposure Metering
- Multi-segment
- Exposure Modes
- Programme, automatic
- Shooting Programs
- Portrait mode, night portrait, PET, scenery, food, night scene, sports mode, sunset, behind glass, high sensitivity, starry sky, soft skin, baby1, baby2, Dynamic Range (HDR)
- Special Effects
- Sepia, soft focus, miniature, Cross Process, Retro, Expressive, high dynamic, High Key, Low Key, Toy effect, Star Filter, Impressive Art, One Point Colour, Dynamic Monochrome, Old Days
- Retouch
- Creative Retouch
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Incandescent, cloudy, daylight, shade
- Max Shutter Speed
- 1/2000 sec
- Min Shutter Speed
- 60 sec
- Exposure Compensation
- ±2 EV range, in 1/3 EV steps
Lens System
- Focal Length Equivalent to 35mm Camera
- 24 - 288mm
- Focus Adjustment
- Automatic
- 3 cm
- Zoom Adjustment
- Motorised drive
- Lens Construction
- 8 groups / 8 elements
- Built-in lens shield, ED glass, aspherical lens
Camera Flash
- Camera Flash
- Built-in flash
- Flash Modes
- Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator
- Effective Flash Range
- 0.6 m - 5.2 m: ISO auto (wide lens) , 1.5 m - 2.6 m: ISO auto (tele lens)
Additional Features
- Continuous Shooting Speed
- 1.2 frames per second, 3 frames per second (3MP)
- Self-Timer Delay
- 10 sec, 2sec
- Additional Features
- Built-in speaker, in-camera red-eye removal, cropping an image, resizing an image, face detection, USB charging, Intelligent Auto (iA), primary colour filter, Creative Panorama function, Creative Control
Display
- 3" LCD display
- Display Format
- 460,000 pixels
- Display Form Factor
- Built-in
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB 2.0 , Composite video/audio output
- Included Accessories
- Hand strap, AC power adaptor, USB cable
- Battery Type
- Lithium Ion - manufacturer-specific
- Details
- Battery Life Details
- Photo shooting - 200 shots
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Image Storage
- JPEG 4608 x 3456 , JPEG 3264 x 2448 , JPEG 2048 x 1536 , JPEG 640 x 480 , JPEG 4608 x 3072 , JPEG 3264 x 2176 , JPEG 2048 x 1360 , JPEG 4608 x 2592 , JPEG 1920 x 1080 , JPEG 3456 x 3456 , JPEG 1536 x 1536
- Video Capture
- MJPEG - 1280 x 720 - 30 fps , MJPEG - 640 x 480 - 30 fps , MJPEG - 320 x 240 - 30 fps
- 9.98 cm
- 2.65 cm
- 6.04 cm
- 144 g
- 0 °C
- 40 °C
