- The OtterBox Symmetry Studio Series case for the Surface Pro 7+/7/6/5/4 undergoes thousands of hours of drop tests to ensure the greatest possible protection for your tablet. The Symmetry Studio Series is easy to install and can withstand as many drops as the military standard (MIL-STD-810G 516.6) specifies.
- The solid one-piece design fits your tablet snugly and its raised edges protect your tablet's screen and camera.
- The keyboard cover attaches effortlessly, and the included pen holder provides convenient carrying and storage.
- The Symmetry Series Studio Case is designed specifically for the Microsoft Surface Tablet - it works with your favorite accessories and fits the kickstand.
- The case is easy to put on.
- Compatible with Surface Pro 7 plus/7/6/5/4
- OtterBox Symmetry Series - back cover for tablet
- Product Type
- Back cover for tablet
- 21.74 cm x 2.08 cm x 30.81 cm
- 205.65 g
- Black crystal
- Designed For
- Microsoft Surface Pro (Mid 2017), Pro 4, Pro 6, Pro 7, Pro 7+
- 21.74 cm
- 2.08 cm
- 30.81 cm
- 205.65 g
- Black crystal
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- Protection
- Drop protection
- Cover Type
- Back cover
- Additional Compartments
- Apple Pencil
- Shipping Dimensions (WxDxH) / Weight
- 22.38 cm x 32.7 cm x 32.54 cm / 2.7635 kg
- Raised edges, DROP+ technology
- MIL-STD-810G 516.6
- Designed For
