With sweeping curves and vibrant graphics, these funky speakers integrate perfectly into any home audio or gaming environment. Genuinely high-impact 40W RMS output with 10W per channel and 20W ported downward-firing subwoofer provides a surprisingly big sound!
The contemporary slim satellites produce an impressive 10W per channel which, when combined with the ported downward-firing subwoofer provides a genuinely high impact sound - whether used as laptop or PC speakers, or as a gaming or home AV setup. With the exciting launches of Xbox One and PS4 why not transform your gaming experience by upgrading your speakers with this affordable Otone solution?
Power on/standby and volume control are integrated in to the right satellite speaker to keep easy adjustment at your fingertips - so there's no need to put your controller down at the wrong moment. And as well as being amongst the best 2.1 PC speakers on the gamer's radar, Eclipse 2.1 also works extremely well as MP3 speakers - giving your digital music a high quality sound whether plugged into a full Hi-Fi system or standalone.
- OTONE Eclipse - speaker system - for PC
- Product Type
- Speaker system - for PC - 2.1-channel
- System Components
- 2 speakers, subwoofer
- Speaker Type
- Active
- Nominal Output Power (Total)
- 40 Watt
- Frequency Response
- 70 - 20000 Hz
- Amplifier
- Integrated
- Speaker System Details
- 2 x satellite speaker 10 Watt , 1 x subwoofer 20 Watt
- 2.6 kg
- 2-year warranty
- Product Type
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 40 Watt
- 70 - 20000 Hz
- Signal-To-Noise Ratio
- 70 dB
- Amplifier
- Integrated
- Controls
- Power on/off, volume
- Speakers Included
- 2 x satellite speaker - 10 Watt - wired , 1 x subwoofer - 20 Watt - wired
- Driver Details
- Satellite speaker: full-range driver - 2"
- Driver Details (2nd speaker)
- Subwoofer: subwoofer driver - 4" - down-firing dome
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- Audio cable, wired remote control
- Power Source
- AC power adapter
- 2.6 kg
- Dimensions (WxDxH) / Weight Details
- Satellite speaker: 8.2 cm x 5.9 cm x 17.2 cm , Subwoofer: 19 cm x 19 cm x 16 cm
- Limited warranty - 2 years
