OTONE Eclipse 2.1 Multimedia Speaker System
Quicklinx: B29NWS00 Mfr#: 11020202
With sweeping curves and vibrant graphics, these funky speakers integrate perfectly into any home audio or gaming environment. Genuinely high-impact 40W RMS output with 10W per channel and 20W ported downward-firing subwoofer provides a surprisingly big sound!
The contemporary slim satellites produce an impressive 10W per channel which, when combined with the ported downward-firing subwoofer provides a genuinely high impact sound - whether used as laptop or PC speakers, or as a gaming or home AV setup. With the exciting launches of Xbox One and PS4 why not transform your gaming experience by upgrading your speakers with this affordable Otone solution?
Power on/standby and volume control are integrated in to the right satellite speaker to keep easy adjustment at your fingertips - so there's no need to put your controller down at the wrong moment. And as well as being amongst the best 2.1 PC speakers on the gamer's radar, Eclipse 2.1 also works extremely well as MP3 speakers - giving your digital music a high quality sound whether plugged into a full Hi-Fi system or standalone.
OTONE Eclipse - speaker system - for PC
Speaker system - for PC - 2.1-channel
System Components
2 speakers, subwoofer
Speaker Type
Active
Nominal Output Power (Total)
40 Watt
Frequency Response
70 - 20000 Hz
Amplifier
Integrated
Speaker System Details
2 x satellite speaker 10 Watt , 1 x subwoofer 20 Watt
2.6 kg
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
40 Watt
Frequency Response
70 - 20000 Hz
Signal-To-Noise Ratio
70 dB
Amplifier
Integrated
Controls
Power on/off, volume
Speakers Included
2 x satellite speaker - 10 Watt - wired , 1 x subwoofer - 20 Watt - wired
Driver Details
Satellite speaker: full-range driver - 2"
Driver Details (2nd speaker)
Subwoofer: subwoofer driver - 4" - down-firing dome
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
Audio cable, wired remote control
Power Source
AC power adapter
2.6 kg
Dimensions (WxDxH) / Weight Details
Satellite speaker: 8.2 cm x 5.9 cm x 17.2 cm , Subwoofer: 19 cm x 19 cm x 16 cm
