Afineo is a richly-featured multimedia speaker, with high-sensitivity twin drivers that produce a combined 32W total RMS output! The downward-firing bass ports enhance lower-midrange and ensure the sound never gets distorted. A smart vertical speaker design means that they can be positioned with a minimal footprint, leaving desk or floor space clear - making them ideal as the best computer speakers you'll hear at this price, or to enhance your SMART TV or MP3 playback. With the exciting launches of Xbox One and PS4 why not transform your gaming experience by upgrading your speakers with this affordable Otone solution?
- OTONE Afineo - speakers - for PC
- Product Type
- Speakers - for PC
- System Components
- 2 speakers
- Speaker Type
- Active
- Nominal Output Power (Total)
- 32 Watt
- Frequency Response
- 80 - 20000 Hz
- Amplifier
- Integrated
- Speaker System Details
- 2 x speaker 16 Watt - 80 - 20000 Hz
- 12 cm x 8 cm x 27.5 cm
- 2.3 kg
- 2-year warranty
- Product Type
- Speakers - for PC
Speaker System
- System Components
- 2 speakers
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 32 Watt
- 80 - 20000 Hz
- Signal-To-Noise Ratio
- 70 dB
- Amplifier
- Integrated
- Controls
- Power on/off, volume, treble, bass
- Additional Features
- Touch sensor buttons
- Speakers Included
- 2 x speaker - 16 Watt - 80 - 20000 Hz - wired
- Driver Details
- Speaker: full-range driver - 2.5"
- Connector Type
- Audio line-in (RCA x 2)
- Power Source
- AC power adapter
- 12 cm
- 8 cm
- 27.5 cm
- 2.3 kg
- Limited warranty - 2 years
