Optoma Panoview 92" Portable Lift 16:9 Pull Up Projection Screen
Quicklinx: 7208WS00 Mfr#: DP-9092MWL
This unique, portable screen is easy to use and very stable with high quality alloy casing and self standing format.
The Panoview Pull Up is an ideal screen for traveling, whether it's from room to room or around the country.
These screens are also great for rental companies were you're unable to mount a screen to the wall or a ceiling.
  • 92" pull-up screen
    92" diagonal 16:9 screen.
  • Intelligent support bar and handle
    For added strength and easy to pull up.
  • Adjustable feet
    Four individual feet to support and level the screen.
  • Portable design
    Lightweight and easy to setup at home or in the office.
Optoma Panoview Pull Up DP-9092MWL - projection screen - 92" (234 cm)
Projection screen
Projection Screen Image Diagonal Size
92" (234 cm)
Projection Image Size
203 cm x 115 cm
Aspect Ratio
16:9
Screen Surface
Matte White
219 cm x 11.5 cm x 15.5 cm
7.5 kg
1-year warranty
Optoma HZ40STx, UHD35x
Projection screen
Image Diagonal Size
92" (234 cm)
Image Width
203 cm
Image Height
115 cm
Screen Surface
Matte White
Aspect Ratio
16:9
Gain
1.0x
Extra Border Size
82 cm (bottom)
Black borders
219 cm - 11.5 cm - 15.5 cm
7.5 kg
Adjustable height
Limited warranty - 1 year
