The Microline 321 printers are suited to high speed, high volume data and word processing applications, where speed is more important than letter quality. Reliability, ease of use and fast throughput make them ideal for customer service points in wholesale, retail and service environments: Multi-part forms, labels, listings, customer service points and accounts.
- OKI Microline 321 - printer - B/W - dot-matrix
- Printer Type
- Personal printer - dot-matrix - 9 pin - B/W
- Form Factor
- Desktop
- 9.5 kg
- Max Media Size
- 406 x 356 mm
- Max Media Size (Custom)
- 406 mm
- Print Speed
- Up to 75 char/sec - near letter , Up to 435 char/sec - max speed , Up to 390 char/sec - draft
- Max Resolution (B&W)
- 240 x 216 dpi
- Interface
- Parallel
- Processor
- No CPU
- RAM Installed (Max)
- 64 KB
- Language Simulation
- EPSON FX, IBM PPR, EPSON ESC/P
- Media Type
- Envelopes, labels, plain paper, continuous forms, cards
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows 3.x/95/98
- 55 cm x 35.5 cm x 11.7 cm
- Printer Type
- Personal printer - dot-matrix - 9 pin - monochrome
- Form Factor
- Desktop
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- Parallel
- 240 x 216 dpi
- PostScript Support
- Not available
- Fonts Included
- 1 x barcode
- Processor
- No CPU
RAM
- 64 KB
Media Handling
- Media Path Type
- Straight
- Media Type
- Max Media Size
- 406 x 356 mm
- 406 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), Roll A4 (21 cm x 50 m), 406 x 356 mm, Roll A3, Roll A4 (21 cm x 30 m)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), Com-10 (105 x 241 mm), US No 6 (92 x 165 mm)
- Max Sheets in Multi-Part Form
- 6
Duty Cycle
- Cartridge / Printhead Duty Cycle
- 200 million characters
- Connections
- 1 x parallel - 36 PIN Centronics
- Plug and Play
- Power Device
- Power supply - integrated
- Voltage Required
- AC 120/230 V ± 10%
- 100 Watt
- Software Included
- Drivers & Utilities
- OS Required
- 5 °C
- 40 °C
- 20 - 90%
- Sound Emission
- 57 dBA
- 55 cm
- 35.5 cm
- 11.7 cm
- 9.5 kg
OKI ML - 182 / 192 / 280 / 320 / 3320 Black | In Stock | £9.14 |
