With color print speeds of 22ppm and mono print speeds of 24ppm, the MC362dn is perfect for small businesses or workgroups providing a variety of functions and the flexibility of printing, scanning, copying and faxing in-house. Helping to manage your internal documents and those you receive, the MC362dn allows you to work smarter and manage your document flow throughout your business or workgroup.
The MC362dn offers duplex printing, scanning, copying and faxing as standard, with an automatic RADF, combined with superior quality high definition color and mono A4 printing that enables you to produce professional looking documents in-house.
Print smart, saving time and money through printing in-house
Management and printing of your documents is so much simpler with the MC362dn, combining high definition color printing with tools that give you the ability to create a full range of documents in-house, allowing you to effectively manage what you print and when you print it. -
Sharp, accurate scanning with useful document management functionality
Providing sharp, fast and accurate scanning, the MC362dn enables you to digitize your documents clearly and with ease. Scan directly to a USB or network TWAIN, whilst LDAP provides direct access to contact and email data from an existing directory server. -
Efficient and cost saving functionality
The MC362dn is built on award winning digital LED technology that is inherently energy efficient with many features and functions that reduce your ongoing costs, including eco and deep sleep modes, plus auto off mode that reduces energy consumption to 0.5W when not in use.
- OKI MC362dn - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- LED (colour)
- Monthly Duty Cycle (max)
- 45000 impressions
- Recommended Monthly Volume
- 3000 pages
- Max Copying Speed
- Up to 24 ppm (mono) / up to 22 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 1200 dpi
- Display
- 3.5"
- Original Size
- A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 210 x 1320 mm (max)
- Media Type
- Envelopes, plain paper, cards, banner
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 880 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail
- Power
- AC 230 V (50/60Hz)
- 42.7 cm x 50.9 cm x 44.4 cm
- 29 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty with product registration
- Copier Type
- Digital
- Fax Type
- Plain paper
- LED - colour
- 45000 impressions
- 3000 pages
- Display Diagonal Size
- 3.5"
- Interface
- Standard Memory
- 256 MB 256 MB
- Max Supported Memory
- 768 MB 768 MB
Copying
- Max Copying Speed
- Preset Enlargements
- 400%
- Preset Reductions
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy, collation copy
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, IBM Proprinter
- Image Enhancement Technology
- OKI ProQ2400 Multilevel
- First Print Out Time B/W
- 8.5 sec
- First Print Out Time Colour
- 9 sec
Scanning
- Optical Resolution
- 1200 x 1200 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 200 pages
Fax Machine Features
- One-Touch Dialing
- 16 station(s)
- Speed Dialing
- 100 station(s)
- Broadcast Transmission
- 100 stations
- Group dialling
Document & Media Handling
- Max Original Size
- A4 (210 x 297 mm)
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- Other
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
- Borderless Photo Sizes
- 102 x 152 mm, 76 x 127 mm, 127 x 178 mm
- 350 sheets
- 880 sheets
- 100 sheets
- 150 sheets
- ADF - 50 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 100 sheets - 210 x 1320 mm weight: 64 g/m² - 220 g/m² , Input tray - 250 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 176 g/m² , Output tray - 150 sheets
- Speed Details
- Copying: up to 24 ppm - B/W , Copying: up to 22 ppm - colour , Printing: up to 24 ppm (A4) - B/W , Printing: up to 22 ppm (A4) - colour , Scanning: up to 20 spm - colour , Scanning: up to 30 spm - B/W
- 1 x USB 2.0 , 1 x USB host , 1 x LAN
- Network Protocols
- TCP/IP, NetBEUI, LPR/LPD, RAW IP (Port 9100), SNMP, HTTP, IPv4, IPv6, Bonjour, FTP, SMTP, DHCP, BOOTP
- SSL, TLS, IPsec, 802.1x, IP filtering, MAC address filtering
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.3.9 - 10.7
- Software Included
- OKI PrintSuperVision, OKI Color Swatch Utility, OKI Color Correct Utility, OKI Template Manager, OKI LPR, Nuance PaperPort SE 11, Nuance OmniPage SE 16
- Voltage Required
- 500 Watt
- Power Consumption Standby
- 100 Watt
- Power Consumption Sleep
- 20 Watt
- First Copy Out Time B/W
- 12 sec
- First Copy Out Time Colour
- 14 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 1000 pages , 1 x toner cartridge (magenta) - up to 1000 pages , 1 x toner cartridge (yellow) - up to 1000 pages
- Supported Windows 7 Features
- Windows HD Imaging
- ENERGY STAR Certified
- Limited warranty - 3 years
- 42.7 cm
- 50.9 cm
- 44.4 cm
- 29 kg
- Sound Emission
- 33 dBA (idle) / 52 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80%
OKI C510DN/C330/C310/C530 Yellow Toner | In Stock | £74.63 |
OKI C510DN/C330/C310/C530 Magenta Toner | In Stock | £74.63 |
OKI C510DN/C330/C310/C530 Cyan | In Stock | £74.63 |
OKI C310/330/510/530 Black Toner | In Stock | £59.10 |
OKI Belt Unit - C510DN/C330/C310/C530 | In Stock | £63.06 |
OKI C310/321/510/530/MC351 Fuser Unit | In Stock | £63.06 |
