- OKI C821dn - printer - colour - LED
- Printer Type
- Workgroup printer - LED - colour
- 40 kg
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- Min Media Size (Custom)
- 148.5 mm x 182 mm
- Max Media Size (Custom)
- 297 mm x 431.8 mm
- Print Speed
- Up to 32 ppm - B/W - A4 (210 x 297 mm) , Up to 22 ppm - colour - A4 (210 x 297 mm) , Up to 17 ppm - B/W - A3 (297 x 420 mm) , Up to 12 ppm - colour - A3 (297 x 420 mm)
- Max Resolution (B&W)
- 1200 x 600 dpi
- Max Resolution (Colour)
- 1200 x 600 dpi
- Image Enhancement Technology
- OKI ProQ2400 Multilevel
- Automatic Duplexing
- Interface
- Parallel, USB, LAN
- Processor
- PowerPC 750CL 700 MHz
- RAM Installed (Max)
- 128 MB (728 MB)
- Language Simulation
- PCL 5C, PostScript 3, EPSON FX, IBM PPR, PCL 6, PDF 1.5, SIDM, PCL XL 3.0
- Media Type
- Envelopes, transparencies, labels, plain paper, recycled paper, banner paper
- Total Media Capacity
- 400 sheets
- Media Handling
- 100-sheet multipurpose tray, 300-sheet input tray
- Monthly Duty Cycle (max)
- 75000 pages
- Recommended Monthly Volume
- 1500 - 5000 pages
- Networking
- Print server - Ethernet, Fast Ethernet - internal
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008, Microsoft Windows Server 2008 x64 Edition, Apple MacOS X 10.3.9 - 10.6
- Microsoft Certification
- Works with Windows Vista
- 48.5 cm x 63.4 cm x 34.5 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 x 600 dpi
- 1200 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 9.5 sec
- First Print Out Time Colour
- 10 sec
- Colour Management Features
- Application-based colour management, ICC Color Profiles
- Media Handling
- Processor
RAM
- 128 MB / 728 MB (max)
Media Handling
- Media Type
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- 148.5 mm x 182 mm
- 297 mm x 431.8 mm
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
- Media Weight
- 64 g/m² - 220 g/m²
- 400 sheets
- Media Feeders
- 1 x automatic - 100 sheets - A3 (297 x 420 mm) weight: 64 g/m² - 220 g/m² , 1 x automatic - 300 sheets - A3 (297 x 420 mm) weight: 64 g/m² - 120 g/m² , 2 x automatic (optional) - 530 sheets - A3 (297 x 420 mm) weight: 64 g/m² - 176 g/m²
- Max Media Capacity
- 1460 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 75000 pages
- 1500 - 5000 pages
- Networking
- Print server - internal
- Data Link Protocol
- Expansion Slots
- Memory
- Connections
- 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x parallel
- Consumables Included
- 1 x toner cartridge (black) - up to 2300 pages ISO/IEC 19752 , 1 x toner cartridge (cyan) - up to 2300 pages ISO/IEC 19752 , 1 x toner cartridge (magenta) - up to 2300 pages ISO/IEC 19752 , 1 x toner cartridge (yellow) - up to 2300 pages ISO/IEC 19752
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 570 Watt
- Power Consumption Stand by / Sleep
- 200 Watt
- Software Included
- OKI LPR, OKI Print Control Client, OKI Print Control Server, OKI PrintSuperVision.net, OKI Swatch Utility, OKI Web Driver Installer, OKI Web Print, OKI Gamma Utility, OKI Profile Assistant, OKI Storage Device Manager, OKI Color Correct, OKI Template Manager, OKI PDF Direct Utility, OKI Color Access Policy Manager
- OS Required
Environmental Standards
- ENERGY STAR
- 10 °C
- 32 °C
- 20 - 80%
- Sound Emission (Idle)
- 37 dBA
- Sound Emission (Operating)
- 54 dBA
- 48.5 cm
- 63.4 cm
- 34.5 cm
- 40 kg
OKI Transfer Belt for C810/830 | In Stock | £127.72 |
