The B401d A4 mono desktop printers offer outstanding quality and duplex printing with fast, reliable performance, all in a low cost, compact and highly competitive priced device. The processor and memory combined help to deliver a fast first page out time and fast throughput. Plus, a generous standard paper tray and a convenient multi-purpose tray (MPT) lets you print longer runs and network connectivity enables sharing across many users.
Efficient working that improves productivity
The processor and memory combined help to deliver a fast first page out time and fast throughput. Plus, a generous standard paper tray and a convenient multi-purpose tray (MPT) lets you print longer runs and network connectivity enables sharing across many users. -
Versatile, cost efficient printing
Flexible media handling combined with the high quality color output, duplex printing and OKI's unique template manager, allows businesses to benefit from printing many of their business requirements in-house.
- OKI B401d - printer - B/W - LED
- Printer Type
- Personal printer - LED - B/W
- 11 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 29 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 2400 x 600 dpi
- Automatic Duplexing
- Interface
- Parallel, USB
- Processor
- PowerPC 405 330 MHz
- RAM Installed (Max)
- 64 MB (64 MB)
- Language Simulation
- PCL 5E, EPSON FX, PCL 6, IBM ProPrinter
- Barcodes
- Code 39, UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, OCR-A, OCR-B, ZIP
- Media Type
- Envelopes, plain paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray, 1-sheet manual tray
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 750 - 2000 pages
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.4 - 10.7
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty with product registration
- 38.7 cm x 36.4 cm x 24.45 cm
- Printer Type
- Personal printer - LED - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- Parallel, USB
- 2400 x 600 dpi
- First Print Out Time B/W
- 5.5 sec
- Fonts Included
- 87 x PCL , 2 x bitmapped
- Barcodes
- Media Handling
- Processor
RAM
- 64 MB / 64 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm)
- Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 250 sheets
- Media Feeders
- 1 x manual - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 30000 pages
- 750 - 2000 pages
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x parallel
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19752
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 510 Watt
- Power Consumption Stand by / Sleep
- 70 Watt
- Software Included
- Drivers & Utilities, OKI Template Manager, OKI Printer Menu Utility
- OS Required
- Limited warranty - 3 years
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 53 dBA
- 38.7 cm
- 36.4 cm
- 24.45 cm
- 11 kg
OKI B401 Black Toner - 2.5k | In Stock | £65.86 |
OKI B401/MB441/451 Black Toner 1.5K | In Stock | £53.87 |
