The ZT series is the superb choice for performance and power users who need solid, reliable PSU. With a completely modular design, ZT Series keeps your internal case environment organized by eliminating wire clutter and improves airflow by using only the cables you require. Kept supremely cool with a load-controlled 140mm fan, the OCZ ZT Series PSU was engineered to be ultra-quiet by eliminating distracting noises from your PC when working or gaming. With an 80-Plus Bronze Certification featuring up to 85% efficiency under typical load environments, this power supply remains rock solid and stable under pressure.
- Continuous output rated at a demanding 45°C ambient temperature
- Built with premium low ESR 105°C electrolytic capacitors
- Single +12V rail for efficient power distribution in your system.
- Compliant with ATX12V v2.2 standard for worry-free compatibility
- A large temperature and load controlled 140mm double ball-bearing fan for whisper quiet operation
- 80-Plus Bronze certified for up to 85% efficiency under real world operating environments
- ErP compliant for low power usage in standby
- Active Power Factor Correction (PFC) to effectively regulate input voltage
- Heavy-duty protection circuitry, (over-voltage, over-current, under-voltage, and short circuit) for protecting your valuable components
- Safety Approvals: UL, CUL, CE, CB, FCC Class B, TÜV, CCC, C-tick.
Connectors
- 1 x 20+4-pin ATX
- 1 x 4+4-pin ESP/12V CPU
- 2 x 6+2-pin PCI-E
- 6 x 4-pin Peripheral
- 9 x 5-pin SATA
- 1 x FDD
- OCZ ZT Series OCZ-ZT650W - power supply - 650 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.2/ EPS12V
- 80 PLUS Certification
- 80 PLUS Bronze
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 650 Watt
- Output Current
- +3.3V - 24 A , +5V - 30 A , +12V - 54 A , -12V - 0.5 A , +5VSB - 3 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 8 pin PCI Express power with detachable 2 pin section , 9 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector , 6 x 4 PIN internal power
- Modular Cable Management
- Cooling System
- 140 mm fan
- 15 cm x 17.5 cm x 8.6 cm
- 5-year warranty
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50/60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 650 Watt
- Output Current
- 80 PLUS Bronze
- MTBF
- 100,000 hours
- Cooling System
- 140 mm fan
- Over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, dual ball bearing cooling fan, fully modular
- FCC Class B certified, UL, TUV, C-Tick, BSMI, GOST, cUL, CB, CCC, RoHS, WEEE, ErP Ready
- Limited warranty - 5 years
- 0 °C
- 45 °C
- 5 - 85%
- 15 cm
- 17.5 cm
- 8.6 cm
