The industry's best SSDs just got better.
Meet the storage expectations you didn't know you had. Engineered by longtime SSD experts, the OCZ Vector Series delivers a new level of untouchable performance, endurance, and reliability designed to empower your laptop or desktop to ba all it can be.
There is a faster, more responsive computing experience inside this box
Imagine faster file transfers, quicker boot ups, and a computer that responds the wy it was designed to and you've got yourself a Vector SSD. It's a 2.5" solid state powerhouse.
If you want lasting reliability, durability, and stealth operation, here is it.
With groundbreaking SSD quality and technology in every drive, the Vector Series is built to provide years of hard drive-humiliating performance that is second to no other storage solution.
- Advanced uite of NAND flash management keeps your drive at higher sustained performance over the long term of maximum endurance
- Excels in both incompressible and compressible data types such as multimedia, encrypted data, ZIP files and software
- Cutting-edge controller technology delivers maximum performance and delivers unmatched endurance without compression or loss of usable capacity, rated for 20GB/day of host writes for 5 years
- Bundled with a 3.6" desktop adapter bracket and an Acronis True Image cloning software registration key to easily transfer data from your old hard drive
- Sleek alloy housing offers slimmer 7mm z-height for compatibility with the latest thinner form factor notebooks
Performance: 256GB
- Sequential Read 550 MB/s
- Sequential Write 530 MB/s
- 4k Random Write 100,000 IOPS
- 4k Random Read 95,000 IOPS
Technical Specifications
- NAND Components Multi-Level Cell (MLC) NAND Flash
- Interface Serial ATA (SATA) 6Gb/s (SATA III)
- Form Factor 2.5-inch; 7mm height
- Dimensions 99.7 (L) x 69.75 (W) x 7mm (H)
- Operating & Storage Temperature 0°C ~ 55°C ; -45°C ~ 85°C
- Controller Indilinx Barefoot 3
- Performance Optimizations TRIM, Idle Time Garbage Collection, SMART Monitoring, ECC
- Shock Resistance Up to 1500G/0.5ms
- Operational Vibration 2.17Grms (7-800Hz)
- Non-Operational Vibration 16.3Grms (20-2000Hz)
- Certifications RoHS, CE, FCC, KCC, C-Tick, VCCI, & BSMI
- Operating System Compatibility Windows, Linux, Mac OS X
- Warranty 5-years Limited
More is more
Advanced controller technology allows Vector to excel in high performance and deliver superior endurance without compression or loss of usable capacity. That means more space and more speed from your Vector SSD. -
Thin is in
With a sleek housing, Vector's slim z-height ensures compatibility with the latest thinner form factor notebooks. Alloy casing lends style that matches your taste for modern storage. -
Faster performance for cost-effectiveness
SSDs have 100x greater throughput and instantaneous access times for quicker boot ups, faster file transfers, and overall snappier performance than hard drives. -
Less power, silent operation
SSDs use significantly less wattage at peak load than hard drives, delivering longer battery life in notebooks, less power strain on system, and a cooler computing environment.
- OCZ Vector Series - SSD - 256 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 256 GB
- NAND Flash Memory Type
- 25nm multi-level cell (MLC)
- Form Factor
- 2.5" Ultra Slim Line (in 3.5" carrier)
- Interface
- SATA 6Gb/s
- Native Command Queuing (NCQ), TRIM support, Idle Time Garbage Collection, S.M.A.R.T., 28/1K bit BCH ECC
- 6.975 cm x 9.97 cm x 7 mm
- 115 g
- 5-year warranty
- Capacity
- 256 GB
- Form Factor
- Interface
- SATA 6Gb/s
- 6.975 cm
- 9.97 cm
- 7 mm
- 115 g
Performance
- Internal Data Rate
- 550 MBps (read) / 530 MBps (write)
- 4KB Random Read
- 100000 IOPS
- 4KB Random Write
- 95000 IOPS
Reliability
- MTBF
- 1,300,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 22 pin Serial ATA
- Compatible Bay
- 2.5" Ultra Slim Line or 3.5" (with included bay adapter)
- Power Consumption
- 2.25 watt (active) , 0.9 watt (idle)
- Software Included
- Acronis True Image HD
- Included Accessories
- 3.5-inch bay adapter
- VCCI, C-Tick, BSMI, FCC, RoHS, KCC
- Limited warranty - 5 years
- 0 °C
- 55 °C
- Shock Tolerance
- 1500 g @ 0.5ms
- Vibration Tolerance
- 2.17 g @ 7-800 Hz (operating) / 16.3 g @ 20-2000 Hz (non-operating)
