OCZ Agility 3 SATA III solid state drives are designed and built to provide an exceptional balance of performance and value. The Agility 3 series implements the cutting-edge SATA 6 Gbps interface to deliver excellent sequential and random data transfer rates, significantly improving your computing experience over hard drives.
In addition to enhanced performance, an Agility 3 upgrade promotes cooler, quieter, and more energy efficient conditions compared to traditional mechanical hard drives. With no moving parts, SSDs provide peace of mind with their superior durability and reliability. Unique and innovative, Agility 3 SSDs deliver a one-of-a-kind storage solution.
120GB Max Performance*
- Max Read: up to 525MB/s
- Max Write: up to 500MB/s
- Random Write 4KB (Aligned): 50,000 IOPS
*Max performance achieved using Native SATA 6Gbps chipset. Please refer to product sheet for additional performance metrics
- Available in 60GB, 120GB, and 240GB Capacities
- MLC NAND Flash
- Interface: SATA 6Gbps / Backwards Compatible 3Gbps
- Native TRIM support
- Seek Time: .1ms
- Slim 2.5" Design
- 99.8 x 69.63 x 9.3mm
- Lightweight: 77g
- Operating Temp: 0°C ~ 55°C
- Storage Temp: -45°C ~ 85°C
- Low Power Consumption: 2.7W Active, 1.5W Idle
- Shock Resistant up to 1500G
- RAID Support
- Compatible with Windows 7, Vista, XP 32-bit/64-bit, Mac OSX, Linux
- MTBF: 2 million hours
- 3-Year Warranty
See The OCZ Agility 3 Solid State Drives In Action!
- OCZ Agility 3 Series - SSD - 120 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 120 GB
- NAND Flash Memory Type
- Multi-level cell (MLC)
- Form Factor
- 2.5" x 1/8H
- Interface
- SATA 6Gb/s
- TRIM support, S.M.A.R.T.
- 70 mm x 100 mm x 9.3 mm
- 77 g
- 3-year warranty
- Capacity
- 120 GB
- Form Factor
- 2.5" x 1/8H
- Interface
- SATA 6Gb/s
- 70 mm
- 100 mm
- 9.3 mm
- 77 g
Performance
- Internal Data Rate
- 525 MBps (read) / 500 MBps (write)
- 4KB Random Read
- 20000 IOPS
- 4KB Random Write
- 50000 IOPS
- Maximum 4KB Random Write
- 85000 IOPS
- Seek Time
- 0.1 ms (average)
Reliability
- MTBF
- 2,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5" x 1/8H
- OS Required
- Linux, Apple MacOS X, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
- FCC, RoHS
- Limited warranty - 3 years
- 0 °C
- 55 °C
