NETGEAR ReadyNAS Duo (1x 2TB) Network Attached Storage (NAS)
Quicklinx: 6CNHWS00 Mfr#: RND2120-100UKS
The ReadyNAS Duo is perfect for homes with more than one computer. Unlike a USB drive, the ReadyNAS connects to the network and is simultaneously accessible via all connected Windows or Macintosh computers. If there is a broadband Internet connection and a home router, the ReadyNAS can be set up to provide secure access to all the stored files remotely via the Internet.
For added protection of stored data, an optional second hard disk drive can be installed. The spare hard drive will keep an extra copy of all the data and instantly take over if the first hard drive should fail. Advanced media streaming support allows the ReadyNAS to directly serve media, with no PC required. Officially licensed BitTorrent client allows downloading to occur without the need for an additional computer. A web-based interface facilitates download management from computers, and a special NETGEAR digital entertainer interface allows management from the select NETGEAR device.
NETGEAR ReadyNAS Duo RND2120 - NAS server - 2 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
2 TB
1 (installed) / 1 (max)
10.1 cm x 22.2 cm x 14.2 cm
English
Storage Controller
1 x RAID SATA 3Gb/s
Hard Drive
1 x 2 TB
Network adapter - integrated - 10Mb LAN, 100Mb LAN, 1GbE
RAM
256 MB
Linux, Apple MacOS X, Microsoft Windows 2000 SP4, Microsoft Windows XP SP1 or later, Microsoft Windows Vista
Environmental Standards
ENERGY STAR Qualified
NAS server
Host Connectivity
Gigabit Ethernet
2 TB
10.1 cm
22.2 cm
14.2 cm
English
Processor / Memory
RAM
256 MB
Flash Memory Installed
64 MB Flash (Firmware)
Storage Controller
1 x RAID - internal
Interface Type
SATA 3Gb/s
Supported Devices
Hard drive
Max Storage Devices Qty
1
Hard Drive
HDD - hot-swap - 3.5" x 1/3H
1 x 2 TB
Network / Transport Protocol
NTP, FTP, DHCP
Remote Management Protocol
HTTP, HTTPS, FTP, SSH
Network Services Compatibility
DHCP, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
Dynamic IP address assignment, DHCP support, E-mail alert, static IP mode, BitTorrent Client
UPnP
Expansion Bays
1 x hot-swap - 3.5" 1/3H
3 x USB 2.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45
1 x network cable
UL, C-Tick, IC, FCC, RoHS
ENERGY STAR Certified
External power adapter
Software Included
Drivers & Utilities
35 °C
20 - 80%
