The NETGEAR RangeMax Dual Band Wireless-N USB 2.0 Adapter WNDA3100 delivers consistent wireless connections using 5 GHz Wireless-N. It works with both 5 GHz and dual band Wireless-N Gateways, Routers and Access Points.
- NETGEAR RangeMax WNDA3100 - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 3 cm x 9.5 cm x 1.5 cm
- 22 g
- Data Link Protocol
- 802.11a, 802.11b/g, 802.11n (draft 2.0)
- Frequency Band
- 2.4 GHz, 5 GHz
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n (draft 2.0)
- System Requirements
- Microsoft Windows Vista / XP
- Microsoft Certification
- Certified for Windows Vista
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0)
- Spread Spectrum Method
- OFDM, DSSS
- Frequency Band
- 2.4 GHz, 5 GHz
Aerial
- Antenna
- Internal
- Directivity
- Omni-directional
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- Software Included
- Drivers & Utilities, NETGEAR Smart Wizard
- OS Required
- System Requirements Details
- Pentium - 300 MHz
- 3 cm
- 9.5 cm
- 1.5 cm
- 22 g
