NETGEAR Nighthawk Mobile Hotspot Router
Quicklinx: DD7CWS00 Mfr#: MR1100-100EUS
Type: Mobile hotspot
Enclosure: External
Interface: Fast Ethernet
Compatibility: [N/A]
£331.98 ex VAT
£398.37 inc VAT
Fast speed for downloading, streaming and media sharing - everything you do at home can now be done virtually anywhere you go.
  • Super-Fast mobile broadband Internet
    Get incredible download speeds of up to 1 Gbps and upload speeds of up to 150 Mbps.
  • Category 16 LTE
    Support for 4GX LTE Advanced Category 16 with 4-band carrier aggregation.
  • Always-on connection
    Never be without Wifi. Connect up to 20 devices on the go.
  • Media streaming
    Stream media from a USB or external hard drive to all your connected devices.
  • Compatible with major service providers
    An unlocked device will accept all SIM cards. Works best on AT&T and T-Mobile networks.
  • Offloading capabilities
    Offload to Wifi or Ethernet to relieve network congestion
NETGEAR Nighthawk M1 Mobile Router - mobile hotspot - 4G LTE Advanced
Mobile hotspot
External
Europe
Max Transfer Rate
1 Gbps
Mobile Communication Protocol
LTE Advanced
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
5040 mAh
10.55 cm x 10.55 cm x 2.035 cm
240 g
1.96 W/kg
Mobile hotspot
External
Built-in Devices
NAS server, 2.4" display
Europe
Modem
Wireless
Qualcomm MDM9x50
Max Transfer Rate
1 Gbps
LTE Advanced
Wireless
Parental control, DLNA Media Server, 4T4R MIMO technology, dual band
Supported Flash Memory Cards
microSD
1 x 1000Base-T - RJ-45 , 1 x USB - Type C , 2 x aerial - TS-9 , 1 x USB 2.0 - Type A
SIM Card Supported
Micro-SIM x 1
1 x USB cable
Power adapter
1.96 W/kg
Lithium Ion
5040 mAh
10.55 cm
10.55 cm
2.035 cm
240 g
Enclosure: External
Brand: NETGEAR
