Your basket is empty
NetGear Fibre Gigabit Module
Quicklinx: 334SWS00 Mfr#: AGM731F
8 in stock
£126.54 ex VAT
£151.84 inc VAT
The Small Form-factor Pluggable (SFP) Gigabit interface Converter (GBIC) slots on NETGEAR's managed switches provide you with a highly adaptable network. You have the option of building your network for copper and/or fiber gigabit connections. Due to the automatic detection capabilities of the switch, installation of the SFP GBIC only requires that you plug the module into the module slot. Plugging an AGM731F module will disable the associated RJ-45 port.
PRODUCT FEATURES:
Adds fiber optic connectivity to the GSM7324;
Small size for high-density fiber connections;
Meets SFP GBIC standard for use with any SFP GBIC compliant slot;
1000BaseSX connectivity;
LC connectors;
Supports both 50um and 62.5um multimode fiber cables.
NETGEAR ProSafe AGM731F - SFP (mini-GBIC) transceiver module
SFP (mini-GBIC) transceiver module - LC multi-mode
Enclosure Type
Plug-in module
1.3 cm x 6.5 cm x 0.9 cm
50 g
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Gigabit Ethernet
Full duplex capability
IEEE 802.3z , UL 1950
Enclosure Type
Plug-in module
1.3 cm
6.5 cm
0.9 cm
50 g
Wired
Cabling Type
1000Base-SX
Gigabit Ethernet
Data Transfer Rate
1 Gbps
IEEE 802.3z
1 x network - Ethernet 1000Base-SX - LC multi-mode
Compatible Slots
1 x SFP (mini-GBIC)
UL 1950
10 - 90%
Type: Modules
Brand: NetGear
Price Range Ex VAT: 100 - 150
