NETGEAR ANT24D18 Antenna 802.11b/g
Quicklinx: 338QWS00 Mfr#: ANT24D18
NETGEAR's ProSafe line of antennas and accessories for 802.11b and 802.11g devices give you multiple options for maximizing the reach and performance of your wireless infrastructure devices. Every WLAN deployment is unique. When planning a network that incorporates wireless, varying facility sizes, construction materials, distance between transmission points and physical obstructions must be accounted for. With both directional and omni-directional antennas, low-loss cables, mounting hardware, and other accessories, installers can customize a value-priced wireless solution that meets the requirements of even the most challenging applications.
The ANT24D18 indoor/outdoor directional antenna provides a 3-in-1 solution for mixed applications in combination with an 802.11b or 802.11g access point or wireless router. One, it delivers extended access point range in a single floor environment ideally positioned in the corner of a building. Two, it functions point-to-point so that you can wirelessly connect LANs between buildings in a campus-type environment. Three, it provides multifloor transmission when placed on a ceiling, as the higher power output extends the range through typical flooring materials. Includes several mounting options (fixed wall, wall adjustable, and pole), cable sold separately.
NETGEAR ProSafe Indoor/Outdoor Patch Panel - antenna
Antenna
26.3 cm x 4 cm x 26.3 cm
1.5 kg
Aerial Placing / Mounting
Ceiling mountable, wall-mountable
Gain
14 dBi
Directivity
Directional
NETGEAR FVM318, FWAG114
Antenna
26.3 cm
4 cm
26.3 cm
1.5 kg
Aerial
Gain
14 dBi
Directivity
Directional
Cabling & Wiring
Connector Provided
1 x N-Series connector female , 1 x SMA female
Mounting Kit
Included
