NETGEAR AirCard 810S Mobile Hotspot HSPA, HSPA+, LTE, DC-HSPA+ 600 Mbps 802.11b/g/n/ac
Quicklinx: C7QTWS00 Mfr#: AC810-100eus
£174.97 ex VAT
£209.96 inc VAT
The AirCard 810S is NETGEARā€™s first commercial mobile hotspot to feature support for Category 11 LTE and 3-band Carrier Aggregation, with the ability to achieve theoretical download speeds of 600 Mbps. AirCard 810S is not only fast but also extremely user-friendly. With a simplified touch screen interface, a long-lasting battery, and a unique jump boosting feature, AirCard 810S is well positioned to offer you a superior mobile broadband experience like never before.
  • Blazingly fast
    Transitioning from Category 6 to Category 11 LTE connectivity means double the peak download speeds, swift application response times, reliable connectivity and a better overall user experience for buffering data-heavy programs such as multimedia and video files.
  • Secure and reliable
    Email and browse online knowing your Internet connection is safe and secure. The NETGEAR AirCard 810S is designed with the latest Wi-Fi security protocols which make it more secure than many public Wi-Fi networks. Also block unwanted devices or turn on guest Wi-Fi to safely share Internet access with others for one-time, temporary use.
  • Shareable Wi-Fi
    The AirCard 810S supports up to 15 Wi-Fi-enabled devices simultaneously - smartphones, latptops and tablets, printers, digital cameras, game consoles, etc. You can securely share your blazing-fast Wi-Fi with friends, family and co-workers while on the go for business or pleasure.
NETGEAR AirCard 810S - mobile hotspot - 4G LTE
Mobile hotspot
External
Max Transfer Rate
600 Mbps
Mobile Communication Protocol
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
2930 mAh - up to 11 hrs
Apple iOS 7.x or later, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 (32/64 bits)
11.2 cm x 1.545 cm x 6.86 cm
132 g
1.26 W/kg
Mobile hotspot
External
Built-in Devices
2.4" touch screen display
Modem
Wireless
Max Transfer Rate
600 Mbps
Antenna
Internal
Wireless
Firewall protection, NAT support, VPN passthrough, Wi-Fi Protected Setup (WPS), Multiple SSID support, 2T2R MIMO technology
2 x aerial , 1 x micro-USB
1 x micro-USB cable
RoHS
1.26 W/kg
Lithium Ion
11.2 cm
1.545 cm
6.86 cm
132 g
35 °C
