The 4th generation GCN architecture is engineered for gamers who play anything from the MOBA's to popular AAA titles. Asynchronous Shaders and an enhanced Geometry Engine power advanced levels of smooth gameplay performance.
Immersive VR experiences
Experience the next level of immersion with the world of VR gaming and entertainment with Radeon RX graphics cards powered by the revolutionary Polaris architecture. -
AMD FreeSync technology
Puts an end to choppy gameplay and broken frames with fluid, artifact-free performance at virtually any framerate. -
HDR compatible
Enhanced contrast and colors deliver a strikingly sharp, colorful, and vivid visual experience. -
Zero FrozrStay undetected
ZeroFrozr technology eliminates fan noise by stopping the fans in low-load situations. This means you can focus on gaming without the noise of spinning fans. -
Airflow Control technology
Using advanced aerodynamics, Airflow Control technology directs more air directly onto the TWIN FROZR VI heat pipes. The special deflectors on the heat sink enlarge the surface area, which means lower temperatures and better gaming. -
Multi GPU
Gaming enthusiasts are always looking for more performance to get the ultimate experience. Using multiple graphics cards in SLI or Crossfire is a great way to find out just how good it gets. MSI GAMING graphics cards fully support multi GPU technologies.
- MSI RX 480 GAMING X 4G - graphics card - Radeon RX 480 - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon RX 480
- Memory
- 4 GB GDDR5
- Core Clock
- 1316 MHz
- Effective Memory Clock
- 7.1 GHz
- Memory Interface
- 256-bit
- Max Monitors Supported
- 4
- Interfaces Details
- 2 x HDMI , 2 x DisplayPort , DVI-D (dual link)
- API Supported
- DirectX 12, OpenGL 4.5
- 4.2 cm x 27.6 cm x 14 cm
- Graphics card
- Bus Type
- Graphics Engine
- AMD Radeon RX 480
- Core Clock
- 1316 MHz
- VR Ready
- 4
- API Supported
- High dynamic-range (HDR) rendering, MSI Solid Capacitor, AMD CrossFireX Technology, MSI Afterburner, Airflow Control technology, FreeSync Technology, MSI Zero Frozr technology, AMD VR Ready Premium, Torx 2.0 Fans, HDCP
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7.1 GHz
- Bus Width
- 256-bit
- Required Power Supply
- 500 W
- Additional Requirements
- 8 pin PCI Express power connector
- 150 Watt
- Software Included
- MSI Afterburner
- 4.2 cm
- 27.6 cm
- 14 cm
- 978 g
