Low Profile Design
- Low profile design saves more spaces.
- User can build slim or smaller system easier.
All Solid Capacitors
- 10 years ultra-long lifetime (under full load).
- Lower temperature and higher efficiency.
- Extreme low ESR.
Afterburner Overclocking Utility
- Support in-game video recording.
- Support wireless control by android/iOS handheld devices.
- Support built-in DX11 effect test.
3DVision Ready
- Support for NVIDIA 3D Vision,bringing a fully immersive stereoscopic 3D experience to the PC.
- MSI N730K-1GD5LP/OCV1 - graphics card - GF GT 730 - 1 GB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce GT 730
- Memory
- 1 GB GDDR5
- Core Clock
- 1006 MHz
- Effective Memory Clock
- 5 GHz
- RAMDAC
- 400 MHz
- Memory Interface
- 64-bit
- Max Resolution
- 4096 x 2160
- Max Resolution Details
- DVI: 2560 x 1600 / HDMI: 4096 x 2160
- Max Monitors Supported
- 2
- Interfaces Details
- HDMI , DVI-D (dual link) , VGA
- API Supported
- OpenGL 4.4, DirectX 12
- 2 cm x 14.5 cm x 6.9 cm
- Bus Type
- Graphics Engine
- Core Clock
- 1006 MHz
- RAMDAC
- 400 MHz
- Max Resolution
- 4096 x 2160 at 60 Hz
- 2
- API Supported
- MSI Solid Capacitor, Nvidia 3D Vision technology, MSI Afterburner, HDCP
- Size
- 1 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5 GHz
- Bus Width
- 64-bit
- Required Power Supply
- 300 W
- 30 Watt
- Software Included
- Drivers & Utilities, Adobe Acrobat Reader, MSI Live Update Series, Norton Internet Security (60 days trial)
- 2 cm
- 14.5 cm
- 6.9 cm
- 140 g
