With every new generation of GPUs comes more performance. With every new generation of MSI TWIN FROZR we give you less noise and heat!
- TWIN FROZR V Thermal Design – 18 months in the development to ensure the cards have the quality and stability to give you the FPS you need.
- TORX Fan Blades – Maximizes downwards airflow and air dispersion to the massive heatsink below.
- Airflow Control Technology – Guides more airflow directly onto the heatpipes by using special deflectors on the heatsink.
- SuperSU Pipe Architecture – A massive nickel-plated copper base plate connected to 8mm heatpipes on the Graphics Card.
- ZERO FROZR Technology – Eliminates fan noise in low-load situations by stopping the fans when they are not needed.
- Independent Fan Control Software – The two fans can work independently of each other.
- Premium White LED Controllable Lighting – Allows you to choose from 5 unique modes to set the right ambience for your gaming moments.
- MSI Afterburner GPU Overclocking Tool – The world’s favourite cross-vendor GPU overclocking software.
- MSI GAMING APP – Overclocking through this app is covered by warranty to take away your worries.
TWIN FROZR V
Cooler, Quieter, Better Gaming
We’ve listened to all your requests and the new TWIN FROZR V is smaller, features stronger fans, generates less noise, keeps your graphics card and its components cooler and matches perfectly with your MSI GAMING motherboard including some funky LED lightning. Our new TORX fans generates more airflow to maximize air dissipation to heatsink, while the advanced dispersion blade design generates 19% more airflow without increasing drag for supreme silent performance.
AIRFLOW CONTROL
Enhanced Dissipation Efficiency
MSI has fitted TWIN FROZR V coolers with the all new Airflow Control technology which guides more airflow directly onto the heat pipes by using special deflectors on the heat sink. In addition, this exclusive heat sink design increases heat sink surface area, greatly enhancing the dissipation efficiency.
SuperSU PIPE
SuperSU Architecture is the best cooling solution for graphics cards. The GPU is cooled by a massive nickel-plated copper base plate connected to Super Pipes (8mm heat pipes) on the MSI GAMING series graphics card. Additionally, the new heat pipe layout increases efficiency by reducing the length of unused heat pipe and a special SU-form design.
ZERO FROZR
Smart Cooling, Stay Quiet
MSI’s TWIN FROZR V Thermal Designs are equipped with Zero Frozr technology which was first introduced by MSI back in 2008. Zero Frozr technology eliminates fan noise in low-load situations by stopping the fans when they are not needed. Compared to other graphics cards, there is no continuous hum of airflow to tell you there’s a powerful graphics card in your gaming rig. This means you can focus on gaming without the distraction of other sounds coming from your PC.
INDEPENDENT FAN CONTROL
Maximum Fan Control, Minimum Noise
The two fans on the TWIN FROZR V Thermal Design can work independently of each other. This means you’ll only have the necessary fan noise given the temperature of the components below the fan. This unique solution gives you the best balance between temperatures and noise and highlights why the MSI TWIN FROZR V is seen as the ultimate Graphics Card cooling solution.
Availability of this feature varies by model.
CATCHING THE VIBE WITH COOL LED EFFECTS
White LED Lighting
Featuring a premium LED illuminated MSI GAMING Dragon to lighten the mood. This brand new function allows you to choose from 5 unique modes to set the right ambience for your gaming moments with just one click using the MSI GAMING APP or control it from the NVIDIA GeForce Experience software.
Graphics Processing Unit (GPU) | NVIDIA GeForce GTX 980Ti |
Interface (Bus Standard) | PCI-Express x16 3.0 |
Core Clock Speed (MHz) | 1178 Core (Boost Clock: 1279) (OC Mode) 1140 Core (Boost Clock: 1228) (Gaming Mode) 1000 Core (Boost Clock: 1076) (Silent Mode) |
Memory Size (MB) | 6144 |
Memory Type | GDDR5 |
Memory Interface | 384 bits |
Memory Clock Speed (MHz) | 7096 |
D-Sub (VGA) Connectors | N/A |
DVI Connectors | 1 (Dual-link DVI-I), Max Resolution: 2560x1600 @60Hz |
HDMI Connectors | 1 (Version 1.4a/2.0), Max Resolution: 4096x2160 @24Hz (1.4a), 3840x2160 @60Hz (2.0) |
DisplayPort | 3 (Version 1.2), Max Resolution: 4096x2160 @60Hz |
Maximum Displays | 4 |
HDCP Support | YES |
DirectX Version Support | 12 |
OpenGL Version Support | 4.4 |
Multi-GPU Technology | SLI, Up to 4-Way |
Card Dimension (mm) | 269 x 140 x 40 |
Power consumption (Watts) | 250 |
Recommended PSU (Watt) | 600 |
Power Connectors (PCI-e) | 2x 8-pin |
Accessories | 1x 8-pin Power Cable, 1x DVI to D-Sub Dongle |
Airflow Diagram
Advanced Dispersion Blade design generates 19% more airflow without increasing drag for supreme silent performance. -
Enhanced dissipation efficiency
MSI has fitted Twin Frozr coolers with the Airflow Control technology which guides more airflow directly onto the heat pipes by using special deflectors on the heat sink. In addition, this exclusive heat sink design increases heat sink surface area, greatly enhancing the dissipation efficiency. SuperSU Architecture is the best cooling solution for graphics cards. The GPU is cooled by a massive nickel-plated copper base plate connected to Super Pipes (8mm heat pipes) on the MSI GAMING series graphics card. Additionally, the heat pipe layout increases efficiency by reducing the length of unused heat pipe and a special SU-form design. -
Smart cooling, stay quiet
MSI's Twin Frozr V Thermal Designs are equipped with Zero Frozr technology which eliminates fan noise in low-load situations by stopping the fans when they are not needed. Compared to other graphics cards, there is no continuous hum of airflow to tell you there's a powerful graphics card in your gaming rig. This means you can focus on gaming without the distraction of other sounds coming from your PC. -
Catching the vibe with cool led effects
Featuring a premium LED illuminated MSI GAMING Dragon to lighten the mood. This function allows you to choose from 5 unique modes to set the right ambience for your gaming moments with just one click. -
MSI gaming app eyerest tab
Quickly adjust display settings to your visual needs. Expand the tab by clicking on the "eyecon" and select your preferred setting. -
More performance
MSI GAMING Graphics Cards give you more performance out of the box. Whether you use the card pre-overclocked or use the Gaming App to use its full potential, you can just get right into the game and enjoy sublime performance. Get in there and start winning! -
Average Gaming Lifetime
One of the deciding factors in performance is the quality of the components used. That is why MSI only uses MIL-STD-810G certified components for its Gaming cards because only these components have proven to be able to withstand the torturous circumstances of extreme gaming and overclocking. -
Hi-c CAP
MSI's Hi-c CAPs are tiny, and super-efficient capacitors. Their small footprint allows the installation of heat sinks and their high efficiency (93%) actually reduces the total thermal footprint of the card. -
Super Ferrite Chokes
Super Ferrite Chokes use a Ferrite core that is Super-Permeable. This allows the Super Ferrite Chokes to run at a 35 degree Celsius lower temperature, have a 30% higher current capacity, a 20% improvement in power efficiency and better overclocking power stability.
- MSI GTX 980TI GAMING 6G - OC Edition - graphics card - GF GTX 980 Ti - 6 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 980 Ti
- Memory
- 6 GB GDDR5
- Core Clock
- 1178 MHz
- Boost Clock
- 1279 MHz
- Effective Memory Clock
- 7.096 GHz
- RAMDAC
- 400 MHz
- Memory Interface
- 384-bit
- Max Resolution
- 4096 x 2160
- Max Resolution Details
- DVI: 2560 x 1600 / DisplayPort: 4096 x 2160 / HDMI: 4096 x 2160
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-I (dual link) , 3 x DisplayPort , HDMI , VGA - with adapter
- API Supported
- OpenGL 4.4, DirectX 12
- 4 cm x 26.9 cm x 14 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1178 MHz
- Boost Clock
- 1279 MHz
- RAMDAC
- 400 MHz
- Max Resolution
- 4096 x 2160 at 60 Hz
- 4
- API Supported
- MSI SuperPipe Technology, MSI Solid Capacitor, Nvidia 4-way SLI ready, MSI Afterburner, MSI Gaming App, Military Class 4 Components, Hi-C CAP, Super Ferrite Chokes, Airflow Control technology, Twin Frozr V Thermal Design, Torx Fans, SuperSU Architecture, MSI Zero Frozr technology, LED illuminated MSI Gaming Dragon, HDCP
- Size
- 6 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7.096 GHz
- Bus Width
- 384-bit
- Required Power Supply
- 600 W
- Additional Requirements
- Two 8-pin power connectors
- 250 Watt
- Included Accessories
- 8 pin power cable
- Cables Included
- 1 x DVI-VGA adapter
- Software Included
- MSI Afterburner, MSI Predator
- MIL-STD 810G
- 4 cm
- 26.9 cm
- 14 cm
- 1.068 kg
