PLAY THE FUTURE - GeForce® GTX™ 950
The GeForce GTX 950 is a true gaming GPU designed for every PC gamer. It’s built to the exacting specifications of the GeForce GTX family and powered by NVIDIA Maxwell™—the most advanced GPU architecture ever created—to deliver 3x the performance of previous-generation cards.
The GeForce GTX 950 transforms your PC into a gaming rig to rival any game console. Enjoy fast and responsive MOBA gaming and the latest games in 1080p. Plus, it delivers a more interactive and cinematic experience with advanced visual effects driven by NVIDIA GameWorks™ and advanced DirectX 12.
FULL HD PERFORMANCE
Maxwell’s exceptional performance and efficiency means you can transform your basic PC into a modern gaming rig that can play the latest games at 1080p.
STEP ABOVE A CONSOLE
More powerful than any console, this card delivers a truly interactive, cinematic experience in the latest games with advanced effects driven by NVIDIA GameWorks™ and DirectX™ 12.
GET THE EDGE FOR MOBA
Competitive gamers demand instant responsiveness and low latency. The GeForce GTX 950 is designed from the ground up for the MOBA gamer, giving you the power and performance to rule the game.
NEW WAYS TO PLAY
GeForce Experience™ makes it easy to share your gameplay or co-play online with friends. With GeForce GTX, stream PC games to your NVIDIA® SHIELD™ devices using NVIDIA GameStream™.
Ready to get real about gaming? Experience the performance of the new GeForce GTX 950.
GPU Boost 2.0 technology
Ensures the GPU runs at its peak performance and games at their highest frame rate possible. Offer new levels of customization including GPU temperature target, overclocking, and unlocked voltage. -
3D vision surround
Support for NVIDIA 3D Vision, bringing a fully immersive stereoscopic 3D experience to the PC. -
Military Class 4 components
Certified to MIL-STD-810G standards for top stability and quality. Built with Hi-c CAP and solid CAP components.
- MSI GTX 950 2GD5 OC - graphics card - GF GTX 950 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 950
- Memory
- 2 GB GDDR5
- Core Clock
- 1076 MHz
- Boost Clock
- 1253 MHz
- Effective Memory Clock
- 6.61 GHz
- RAMDAC
- 400 MHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- Max Resolution Details
- DVI: 2560 x 1600 / DisplayPort: 4096 x 2160 / HDMI: 4096 x 2160
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-I (dual link) , DisplayPort , HDMI , DVI-D (dual link)
- API Supported
- DirectX 12, OpenGL 4.5
- 3.7 cm x 17 cm x 11.1 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1076 MHz
- Boost Clock
- 1253 MHz
- RAMDAC
- 400 MHz
- Max Resolution
- 4096 x 2160 at 60 Hz
- 4
- API Supported
- MSI Solid Capacitor, Nvidia 3D Vision Surround Ready, Nvidia 2-way SLI ready, MSI Afterburner, NVIDIA GPU Boost 2.0, Military Class 4 Components, Hi-C CAP, HDCP
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.61 GHz
- Bus Width
- 128-bit
- Required Power Supply
- 350 W
- Additional Requirements
- 6 pin PCI Express power connector
- 90 Watt
- Software Included
- Adobe Acrobat Reader, MSI Live Update Series, Microsoft DirectX, MSI Afterburner, display drivers, Norton Internet Security (60 days trial)
- MIL-STD 810G
- 3.7 cm
- 17 cm
- 11.1 cm
- 439 g
