Low Profile Design
- Low profile design saves more spaces.
- User can build slim or smaller system easier.
Noise Free
- Large heat sink covers the area of GPU and memory.
- Providing the best environment for gaming and multimedia.
All Solid Capacitors
- 10 years ultra-long lifetime (under full load).
- Lower temperature and higher efficiency.
Afterburner Overclocking Utility
- Monitor fan speed profile.
- In-game video recording.
- iOS/Android remote control.
- Built-in DX11.2 benchmark.
Video Output Function
- Dual-link DVI-D x 1
- HDMI x 1 (version 1.4a)
- D-Sub x 1
- MSI N720-2GD3HLP - graphics card - GF GT 720 - 2 GB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce GT 720
- Memory
- 2 GB DDR3
- Core Clock
- 797 MHz
- CUDA Cores
- 192
- Effective Memory Clock
- 1.6 GHz
- RAMDAC
- 400 MHz
- Memory Interface
- 64-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 3
- Interfaces Details
- HDMI , DVI-D (dual link) , VGA
- API Supported
- OpenGL 4.4, DirectX 12
- Fanless
- 2 cm x 16.2 cm x 6.9 cm
- Graphics card - low profile - fanless
- Bus Type
- Graphics Engine
- Core Clock
- 797 MHz
- CUDA Cores
- 192
- RAMDAC
- 400 MHz
- Max Resolution
- 4096 x 2160 at 24 Hz
- 3
- API Supported
- MSI Solid Capacitor, Nvidia 3D Vision technology, MSI Afterburner, HDCP
- Size
- 2 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.6 GHz
- Bus Width
- 64-bit
- Required Power Supply
- 300 W
- 23 Watt
- Software Included
- Drivers & Utilities, Adobe Acrobat Reader, MSI Live Update Series, Microsoft DirectX, MSI Live, MSI Afterburner, MSI StarOSD, MSI Dual Core Center, Norton Internet Security 2008 (60 days trial)
- 2 cm
- 16.2 cm
- 6.9 cm
- 198 g
