MSI GeForce GT 610 810MHz 2GB PCI-E 2.0 HDMI LP
Quicklinx: 97SYWS00 Mfr#: N610-2GD3H/LP
  • High-Definition Multimedia Interface (HDMI)
MSI graphics card products utilities high quality solid capacitor. For the gamers and high-end users, this feature not only means that product has better quality components within, but also provide much stronger support while users want to engage in hard-core tuning.
MSI graphics card offers the HDMI functionality to provide access to premium digital content. HDMI enables gaming enthusiasts to seamlessly connect to their LCD monitor to bring the ultimate multimedia experience.
  • MSI solid capacitor graphic cards
  • PhysX
    PhysX is designed specifically for hardware acceleration by powerful processors with hundreds of cores. Combined with the tremendous parallel processing capability of the GPU, PhysX will provide an exponential increase in physics processing power and will take gaming to a new level delivering rich, immersive physical gaming environments.
  • NVIDIA CUDA technology
    NVIDIA CUDA technology is the world's only C language environment that enables programmers and developers to write software to solve complex computational problems in a fraction of the time by tapping into the many-core parallel processing power of GPUs. With millions of CUDA-capable GPUs already deployed, thousands of software programmers are already using the free CUDA software tools to accelerate applications - from video and audio encoding to oil and gas exploration, product design, medical imaging, and scientific research.
  • HDMI + DVI output
    HDMI + DVI output HDMI and DVI are the most comprehensive used interfaces for high definition video display. MSI adopts two interfaces to provide a complete output solution for users to enjoy the HD video such as Blu-ray movie.
  • HDMI convertible output
    Dual-link DVI convertible output supports video/audio signal integration through DVI to HDMI interface, which drivers resolution of a digital display up to 1920 x 1200 or higher.
  • NVIDIA PureVideo HD technology
    Blu-ray and HD DVD movies are bringing a new level of movie-viewing experience; with high-definition image quality far surpassing standard-definition DVDs. NVIDIA PureVideo HD2 technology provides unsurpassed Blu-ray and HD DVD movie picture quality.
  • Blu-ray and HD DVD support
    Both support the Blu-ray and HD DVD (High Definition DVD). It comes with the GPU and DDRIII superior processing performance in which users can easily enjoy the high-definition video of 1920 x 1080.
  • HDMI support
  • PCI Express 2.0 support
    Designed to run perfectly with PCI Express 2.0 bus architecture, offering a future proofing bridge to tomorrow's most bandwidth-hungry games and 3D applications by maximizing the 5 Gtps PCI Express 2.0 bandwidth (twice that of first generation PCI Express). PCI Express 2.0 products are fully backwards compatible with existing PCI Express motherboards for broadest support.
  • Meet RoHS regulations
    MSI products are the first to be in conformity of the EU's RoHS (Restriction of Hazardous Substances) regulations, reducing heavy metals and toxic materials in the products. This is an effort made for the Earth, and essentially for a clean future.
  • HDCP support
    The HDCP provides a robust, cost-effective and transparent method for transmitting and receiving digital entertainment similar to DVI/HDMI-compliant digital displays. HDCP encrypts the date transmitted between the DVI/HDMI connector on the graphics adapter and the display.
MSI N610-2GD3H/LP - graphics card - GF GT 610 - 2 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA GeForce GT 610
2 GB DDR3
Core Clock
810 MHz
CUDA Cores
48
Effective Memory Clock
1.334 GHz
Memory Interface
64-bit
DVI-I (dual link) , HDMI , VGA
API Supported
DirectX 11, OpenGL 4.2
Fanless
3.3 cm x 16.7 cm x 5.4 cm
Graphics card - low profile - fanless
Bus Type
PCI Express 2.0 x16
Graphics Engine
Core Clock
810 MHz
CUDA Cores
48
API Supported
Native HDMI, MSI Solid Capacitor, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, HDCP
Size
2 GB
DDR3 SDRAM
Effective Clock Speed
1.334 GHz
Bus Width
64-bit
32 Watt
Software Included
Drivers & Utilities, MSI Afterburner 2.2, MSI Predator
3.3 cm
16.7 cm
5.4 cm
