Military Class 4 is the next step in high quality components. The Super Ferrite Choke and Solid CAP will make sure that your PC runs more stable under extreme gaming conditions.
Super Ferrite Chokes use a Ferrite core that is Super-Permeable. This allows the Super Ferrite Chokes to run at a 35 degree Celsius lower temperature, have a 30% higher current capacity, a 20% improvement in power efficiency and better overclocking power stability.
With their aluminum core design and quality, Solid CAPs are made for high-end design motherboard. Not only do Solid CAPs could provide lower Equivalent Series Resistance (ESR), but also work firmly for over-10-year.
No more seamless waiting for your O/S to be loaded! MSI Fast Boot helps to make your system boot lightning fast. MSI Fast Boot also features a GO2BIOS button. Simply click it to restart your PC and go straight to the system BIOS.
Compared to the 480Mbps provided by traditional USB 2.0, the USB 3.0's 5Gb/s offers 10 times the transfer bandwidth, so transferring a Blu-ray movie takes less than one minute.
Military Class 4
Military Class 4 is the next step in high quality components. The Super Ferrite Choke and Solid CAP will make sure that your PC runs more stable under extreme gaming conditions. -
Super Ferrite Chokes use a Ferrite core that is Super-Permeable. This allows the Super Ferrite Chokes to run at a 35 degree Celsius lower temperature, have a 30% higher current capacity, a 20% improvement in power efficiency and better overclocking power stability. -
Solid CAP
With their aluminum core design and quality, Solid CAPs are made for high-end design motherboard. Not only do Solid CAPs could provide lower Equivalent Series Resistance (ESR), but also work firmly for over-10-year. -
Military Class essentials
The core of Military Class 4 is based on the essentials which increase your stability in the worst conditions. The humidity protection and high temperature protection ensure your system surviving each environment, no matter how harsh. The structure of the PCB limits EMI radiation. On top of that all the connectors have ESD protection in order to prevent short circuit. -
Humidity Protection
Gen 4 Fabric PCB helps to against moisture cause by some humid conditions and environments. -
EMI Protection
The optimized EMI-proof design helps to keep users safe when during a long-time computer operation. -
ESD Protection
Anti-ESD ICs and fuses onboard helps to totally protect your motherboard from electrostatic damage. -
HIGH Temperature Protection
Certificated Military Class 4 components help to work stable under some extreme conditions. -
Fast Boot
No more seamless waiting for your O/S to be loaded! MSI Fast Boot helps to make your system boot lightning fast. MSI Fast Boot also features a GO2BIOS button. Simply click it to restart your PC and go straight to the system BIOS. -
M-Flash
Compared to common motherboards which need extra BIOS chips, MSI's M-Flash has a double advantage which doesn't need extra components and secondly, all your BIOS data will be saved in the USB drive. The stored data does not only have backup and upgrade function, moreover, it can also be seen as a portable BIOS chip which is actually able to boot up your PC. -
USB 3.0
Compared to the 480Mbps provided by traditional USB 2.0, the USB 3.0's 5Gb/s offers 10 times the transfer bandwidth, so transferring a Blu-ray movie takes less than one minute. -
SATA 6Gb/s
SATA 6Gb/s provides double the bandwidth of traditional SATA 3Gb/s, and increases the data transfer rate between your motherboard and internal storage devices, such as 7200RPM HDDs, 10000RPM HDDs and SSDs. It's also the current trend for upcoming high-speed internal storage devices to break the existing bottleneck of a PC's performance. -
USB Safeguard
USB Safeguard can prevent motherboards and USB devices from being damaged by short-circuit and ESD (Electro-Static Discharge) with Anti-ESD chips built-into the motherboards. Additionally, the safeguard can protect against such dangers multiple times, and greatly improves product lifespan.
- MSI A68HM-P33 V2 - motherboard - micro ATX - Socket FM2+ - AMD A68H
- Product Type
- Motherboard - micro ATX
- Chipset Type
- AMD A68H
- Processor Socket
- 1 x Socket FM2+
- Compatible Processors
- Athlon, A series
- Max RAM Size
- 32 GB
- RAM Supported
- 2 DIMM slots non-ECC, unbuffered
- Storage Ports
- 4 x SATA-600 (RAID)
- USB / FireWire Ports
- 2 x USB 3.0 + 2 x USB 2.0 + (4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 2048 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Chipset Type
- AMD A68H
- Processor Socket
- Socket FM2+
- Max Processors Qty
- 1
- Athlon, A series
Supported RAM
- Max Size
- 32 GB
- Bus Clock
- 1600 MHz, 1333 MHz, 1866 MHz, 2133 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP), AMD Memory Profile (AMP)
Graphics
- 2048 MB
Audio
- Audio Codec
- Realtek ALC887
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8111G
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 1 x PCIe x1 , 1 x PCI (3.3 V/ 5 V)
- Storage Interfaces
- SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10
- 1 x PS/2 keyboard , 2 x USB 3.0 , 1 x VGA , 1 x DVI , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 mouse
- Internal Interfaces
- 1 x audio - header , 4 x USB 2.0 - header , 1 x serial - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Features
- M-Flash, UEFI BIOS, MSI ClickBIOS 4
- Hardware Features
- AMD Cool 'n' Quiet Technology, USB Safeguard, All-Solid Capacitor motherboard Design, Intel Extreme Memory Profile (XMP) support, MSI Winki 3, AMD Radeon Dual Graphics, Super Ferrite Choke (SFC), AMD Memory Profile (AMP) support, MSI Military Class IV, Military Class Essentials, MSI Fast Boot
- Software Included
- MSI Live Update 6
- 22.6 cm
- 17.3 cm
