A member of the highly successful MC9000 Series, the MC9190 gives your workers the ability to process information and take action quickly and accurately, even in the harshest of environments.
Proven rugged construction, ready for your most challenging environments
Every day, the MC9000 Series devices deliver reliable performance, despite everyday drops on concrete, subzero cold, extreme heat, dust, spills and more. -
Six advanced scan engines
No matter what type of barcodes are in use in your facility, there is a scan engine option that is optimized for rapid-fire capture of 1-D, 2-D, driver's license, DPM codes and more - even if the codes are dirty, damaged or poorly printed. -
Change keypads in minutes
A family of six interchangeable keypads makes data entry easy for any type of application, if your data entry requirements change or the keypad is damaged, the modular architecture allows you to change the keypad in minutes, right on site. -
Backwards compatibility with all MC9000 accessories
Upgrade to the latest mobile technology advancements while preserving your existing accessory investments.
- Zebra MC9190-G - data collection terminal - Win Mobile 6.5 Classic - 3.7"
- Product Type
- Data collection terminal - rugged
- Operating System
- Microsoft Windows Mobile 6.5 Classic
- Display
- 3.7" colour - 640 x 480
- Processor
- Marvell XScale PXA320
- Processor Clock Speed
- 806 MHz
- RAM
- 256 MB
- Supported Flash Memory Cards
- SD Memory Card, MultiMediaCard
- Wireless Connectivity
- 802.11a/b/g, Bluetooth 2.1 EDR
- Barcode Reader
- Yes (laser)
- 9.1 cm x 23.1 cm x 19.3 cm
- 0.71 kg
- Product Type
- Operating System
Display
- 3.7" colour
- Resolution
- 640 x 480
- Processor
- 806 MHz
- RAM
- 256 MB
- ROM
- 1 GB
Communications
- LEAP, TLS, WPA2, 802.1x, AES-CCMP
Input Device
- Keyboard
- Keys Qty
- 53
Barcodes
- Barcode Reader
- Scan Element Type
- Laser
- Max Working Distance
- 13.7 m
Expansion and Connectivity
- Expansion Slots
- 1 x SD Memory Card
- Installed Qty (Max Supported)
- 1
- Technology
- Lithium Ion
- Capacity
- 2200 mAh
- EN55024, EN55022 Class B, FCC Part 15.247, RSS-210, RSS-102, FCC Part 15, IEC 62040-2 class B, RoHS, FIPS 140-2, FCC Part 2, UL 60950-1, IEC 60950-1, EN 60950-1, ICES Class B, MIL-STD 810G, IP64, IEC 60825-1, FCC Part 15.407, FDA, CCX V4, EN 50371, EN 60825-1, CSA 22.2, ICSA SSL-TLS, EN 300 328, EN 301 489-1, EN 301 893, EN 301 489-17
- 9.1 cm
- 23.1 cm
- 19.3 cm
- 0.71 kg
- -20 °C
- 50 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
Motorola GUN.802.11A/B/G LORAX VGA COLO
