Secured connection, reliable performance control and convenience are at your fingertips with this compact keyboard and reliable mouse. The strong and secured wireless signal allows you to choose where you want to work. And the desktop is easy to use - just load batteries, plug in the transceiver, and start typing.
Secured wireless connection
Microsoft 2.4GHz wireless delivers a secured and reliable connection with up to 15-foot range. -
Easy-access hot keys
Quickly access calculator, volume controls, mute, and play/pause. -
Microsoft optical technology
1000dpi provides responsive cursor control. -
Snap-in transceiver
Stows conveniently under mouse for portability. Power switch turns the mouse on and off for up to 8 months of battery life.
- Microsoft Wireless Desktop 800 for Business - keyboard and mouse set - UK - black
- Keyboard and mouse set
- Interface
- 2.4 GHz
- Wireless Receiver
- USB wireless receiver
- Connectivity Technology
- Wireless
- Localization and Layout
- UK
- Hot Keys Function
- Calculator, volume, mute
- Pointing Device
- Mouse - optical
- Scrolling wheel, on/off power switch, 1000 dpi resolution, right and left-handed
- Black
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty
- Interface
- 2.4 GHz
- Wireless Receiver
Input Device
- Wireless
- Hot Keys Function
- UK
Pointing Device
- Mouse
- Movement Detection Technology
- Optical
- Pointing Device Features
- Black
- OS Required
- Apple MacOS X 10.4.x - 10.6.x, Microsoft Windows Vista / XP / 7
- Limited warranty - 2 years
