Microsoft's most portable wireless notebook mouse connects directly to a Bluetooth PC without a transceiver, freeing up USB ports for other devices.
Transceiver free convenience
Enjoy reliable, transceiver-free wireless connection to your Bluetooth PC. -
High definition laser technology
Microsoft high definition laser mouse products are more precise, more responsive, and deliver smoother tracking. -
Battery life indicator
You won't get caught with a dead battery - the battery status LED Indicator glows red when the battery is running low. -
Ergonomic design
Point and click in comfort - ergonomic design helps you work longer without discomfort. -
Back button
Use the Back button to easily navigate between folders and Web pages, or press the wheel for auto-scroll. -
Scroll wheel
Save time and effort with the scroll wheel - navigate documents and Web pages without using the on-screen scroll bar. -
Comfort for either hand
Use your mouse with your left or right hand - ambidextrous design makes it comfortable either way. -
On/off button
Turn your mouse device off to extend battery life even longer. -
4 buttons
Use the Back button to easily navigate folders or web pages, and press the scroll wheel for AutoScroll. -
Designed for notebook PCs
Compact and comfortable, our handy notebook and laptop products are designed for convenience and mobility.
- Microsoft Bluetooth Notebook Mouse 5000 for Business - mouse - Bluetooth
- Mouse
- Connectivity Technology
- Wireless - Bluetooth
- Orientation
- Right and left-handed
- Movement Detection Technology
- Laser
- Buttons Qty
- 4
- Movement Resolution
- 1000 dpi
- Scrolling wheel, rubber side grips, High Definition Laser Technology, battery indicator, on/off power switch
- OS Required
- Apple MacOS X 10.2 or later, Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista
- 3-year warranty
- Mouse
- Orientation
Input Device
- Wireless
- Interface
- Bluetooth
- Max Operating Distance
- Up to 10 m
- Laser
- Buttons Qty
- 4
- 1000 dpi
- OS Required
- Limited warranty - 3 years
