High fidelity bookshelf stereo speakers with beautiful wood finish
Designed with Microlab special care and audio expertise, this series is ideal for most living room setup. Listen to crystal clear and dynamic music with this stereo pair and witness the quality in its audio drivers.
High resolution and near perfect performances, simply stunning audio production quality.
Powerful sharp cone dispersion design on woofer for perfect audio experience.
Comes with infrared remote control capability for wireless remote control.
Special heritage range for Microlab's 2.0 system that employs high quality design techniques and speaker technology - perfect sound quality and near linear response.
Incorporates IGBT OCL circuit for pure tones and dynamic acoustic production. Wireless remote control for attenuation.
High quality sound and full range spectrum, ideal for all music lovers and audiophiles.
Technical Specifications:
Amplifier:
Output power: 100 Watt RMS
Power distribution: 50 Watt x 2
Harmonic distortion: < 0.3% 1W 1kHz
Frequency response: 55Hz - 20kHz
Signal/Noise ratio: > 85dB
Separation: > 55dB
Input sensitivity: 440mV
Nominal impedance: 4 ohm
Speakers:
Tweeter driver type: 1"
Tweeter rated power: 10 Watt 6 ohm
Bass driver type: 6.5"
Bass rated power: 30 Watt
Frequency range: 55Hz - 20kHz
Interfaces:
Output: Terminals
Input: 2RCA
Aux input: 2RCA
Power:
Power supply: AC 220 - 240V, 50Hz
Package Contents:
SOLO6C speakers x 2
Interconnect cable
2RCA - 3.5mm stereo 1.8m cable
Full function remote control
User manual
Click Here to see a review of the Microlab Solo 6C Speakers from Kitguru
- Microlab SOLO-6C - speakers - for PC
- Product Type
- Speakers - for PC
- System Components
- 2 speakers
- Speaker Type
- 2-way - active
- Continuous Power
- 50 Watt
- Frequency Response
- 55 - 20000 Hz
- Speaker System Details
- 2 50 Watt - 55 - 20000 Hz
- 21 cm x 27.2 cm x 36.1 cm
- Product Type
- Speakers - for PC
- Enclosure Material
- MDF
Speaker System
- System Components
- 2 speakers
- Speaker Type
- 2-way - active
- Continuous Power
- 50 Watt
- 55 - 20000 Hz
- Magnetic Shield
- Speakers Included
- 2 - 2-way - 50 Watt - 55 - 20000 Hz - wired
- Driver Details
- Woofer driver - 6.5" , Tweeter driver - 1"
- Power Source
- AC power adapter
- 21 cm
- 27.2 cm
- 36.1 cm
