Special heritage range for Microlab's 2.0 system that employs high quality design techniques and speaker technology - perfect sound quality and near linear response. It incorporates IGBT OCL circuit for pure tones and dynamic acoustic production. It features high quality sound and full range spectrum and is ideal for all music lovers and audiophiles.
Beautiful wooden cabinets with excellence sound quality
Crystal clear dynamic highs, balanced mid range and deep bass.
Reference monitor quality, driven by high quality drivers.
Each cabinet with 1" tweeter for high notes and woofer for mid to low depths and bass.
Ideal for music, movies and digital media playbacks
Technical Specifications
Amplifier specs
Output power: 60, Watt RMS
Power distribution: 30x2, Watt
Harmonic distortion: 0,3, % (1Watt, 1kHz)
Frequency response: 64-20 000, Hz
Signal/Noise ratio: 75, dB
Separation: 50, dB
Speakers specs
Tweeter driver: type 1,
Bass driver type: 5,
Material: MDF
Color: dark wood
Remote control: 1
Output: terminals
Input: 2RCA
Dimensions
Satellites: 183 x 300 x 212, mm
Product Net weight: 10,40, kg
- Microlab SOLO-1C - speakers - for PC
- Product Type
- Speakers - for PC
- System Components
- 2 speakers
- Speaker Type
- 2-way - active
- Continuous Power
- 30 Watt
- Frequency Response
- 64 - 20000 Hz
- Amplifier
- Integrated
- Speaker System Details
- 2 30 Watt - 64 - 20000 Hz
- Power
- AC 230V (50 Hz)
- 18.3 cm x 21.2 cm x 30 cm
- Product Type
- Speakers - for PC
- Enclosure Material
- Wood
Speaker System
- System Components
- 2 speakers
- Speaker Type
- 2-way - active
- Continuous Power
- 30 Watt
- 64 - 20000 Hz
- Signal-To-Noise Ratio
- 75 dB
- Amplifier
- Integrated
- Speakers Included
- 2 - 2-way - 30 Watt - 64 - 20000 Hz - wired
- Driver Details
- Woofer driver - 5" , Tweeter driver - 1"
- Connector Type
- Audio line-in (RCA x 2)
- Included Accessories
- Audio cable, remote control
- Remote Control
- Remote control - infrared
- Power Device
- Power supply
- Power Source
- AC power adapter
- Voltage Required
- AC 230V (50 Hz)
- 18.3 cm
- 21.2 cm
- 30 cm
