Portable stereo speakers for tablets and notebooks.
Enhance and power your tablet music and sound.
Compact design and small soundbar system with two quality speaker drivers. Broaden your tablet sound range and listen to distinct sound effects.
Easy connection with 3.5mm stereo plug and mount your tablet in front for quick setup. Comes with rechargeable battery for portability. Travel with your tablet and enjoy to enhanced sound everywhere you go.
Watch movies and listen to music while on-the-move.
-Quality stereo speaker system with built-in amplifier
-Ideal for movies, gaming, music and pc applications
-Clear and uncoloured sound
-Soundbar type design
-Connects to any 3.5mm stereo jack easily e.g., tablet, PC, notebook, Mp3/Mp4, CD/DVD player, etc.
-Rechargeable battery with easy replacement
-Two power modes: USB or Lithium battery powered
-3.5 mm stereo plug and wire connected to speaker; no separate cable required.
Technical Specifications
Amplifier specs
Output power 2, Watt RMS
Power distribution 1x2, Watt
Harmonic distortion 0,5, % (1Watt, 1kHz)
Frequency response 150-20 000, Hz
Signal/Noise ratio 75, dB
Separation 40, dB
Speakers specs
Tweeter driver type 1,5,
Tweeter rated power 2, Watt
Material piastic
Input 3,5 mm stereo
Dimensions
Satellites 195x59.5x57, mm
Product Net weight 0,44, kg
- Microlab MD220 - speaker - for portable use
- Product Type
- Speaker - for portable use
- Speaker Type
- Active
- Continuous Power
- 2 Watt
- Frequency Response
- 150 - 20000 Hz
- Amplifier
- Integrated
- Speaker Details
- Speaker - stereo x 2 - 1 Watt - 150 - 20000 Hz - 4 Ohm - active
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Power Options
- USB charging, USB powered
- Battery
- Speaker battery rechargeable - Lithium Ion
- 19.5 cm x 5.7 cm x 5.95 cm
- 350 g
- Product Type
Speaker System
- Speaker Type
- Active
- Continuous Power
- 2 Watt
- 150 - 20000 Hz
- Signal-To-Noise Ratio
- 75 dB
- Total Harmonic Distortion
- 0.5%
- Amplifier
- Integrated
Speaker System Details
- Speaker Details
- Speaker - stereo x 2 - 1 Watt - 150 - 20000 Hz CFR - 4 Ohm - active
- Driver Details
- Speaker: full-range driver - 1.5"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , DC power input
- Included Accessories
- Audio cable, USB charge cable
- Power Source
- Battery
- Options
- Rechargeable - Lithium Ion
- 19.5 cm
- 5.7 cm
- 5.95 cm
- 350 g
