Incorporating Bluetooth technology for wireless music entertainment. This system lets you connect to your mobile phone or media player without cables. Using A2DP or AVRCP profiles, it lets you listen to stereo music by connecting to any Bluetooth enabled device.
Designed with beautiful leather finishes, this versatile stereo system fits perfectly in your living room, computer room or even your bedroom. Bass reflex tunnel design means deeper bass effects. Classic bookshelf stereo speaker arrangement creates better dynamic sound movements for realistic effects.
Ideal for digital movies, TV. PC / notebooks, CD / DVD and multimedia application.
Comes with two audio methods, wireless Bluetooth music transfer and traditional audio connection.
Technical Specifications
Amplifier specs
Output power - 36, Watt RMS
Power distribution - 18x2, Watt
Harmonic distortion - 0,3, % (1Watt, 1kHz)
Frequency response - 50-20 000, Hz
Signal/Noise ratio - 70, dB
Separation - 60, dB
Speakers specs
Tweeter driver type - 1
Bass driver type - 3.5
Material - MDF
Output - terminals
Input - 2RCA
Auxilliary - Bluetooth
Dimensions
Satellites - 116x198x202 , mm
Product Net weight - 4.7, kg
- Microlab H21 - speakers - wireless
- Product Type
- Speakers
- System Components
- 2 speakers
- Enclosure Design
- Bass reflex
- Speaker Type
- 2-way - active
- Nominal Output Power (Total)
- 36 Watt
- Frequency Response
- 50 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Speaker System Details
- 2 18 Watt - 50 - 20000 Hz
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Power
- AC 120/230 V (50/60 Hz)
- 4.7 kg
- 1-year warranty
- Product Type
- Speakers
- Enclosure Design
- Bass reflex
- Enclosure Material
- Wood
- Design Features
- Leather finish
Speaker System
- System Components
- 2 speakers
- Speaker Type
- 2-way - active
- Audio System Continuous Power (Total)
- 36 Watt
- 50 - 20000 Hz
- Signal-To-Noise Ratio
- 70 dB
- Total Harmonic Distortion
- 0.5%
- Amplifier
- Integrated
- Bluetooth 2.1 EDR
- Recommended Placing
- Bookshelf
- Controls
- Volume
- Interface Type
- Bluetooth
- Additional Features
- Charging
- Speakers Included
- 2 - 2-way - 18 Watt - 50 - 20000 Hz - bookshelf - wired
- Driver Details
- Woofer driver - 3.5" , Tweeter driver - 1"
- Connector Type
- Audio line-in (RCA x 2) , DC power input , DC power output (4 pin USB Type A (power only))
- Included Accessories
- Audio cable, power adapter, speaker cable
- Power Device
- Power adapter - external
- Voltage Required
- 4.7 kg
- Dimensions (WxDxH) / Weight Details
- Right channel speaker: 11.6 cm x 20.2 cm x 19.8 cm , Left channel speaker: 11.6 cm x 20.2 cm x 18.9 cm
- Limited warranty - 1 year
