Professionally design for superb Hi-Fi performance. Microlab FineCone series multimedia speakers select the stunning V12 speaker unit which is designed by Denmark famous speaker designer Peter Larsen, handing down Denmark style to recreate the purest sound.
Microlab premier range, the FC series is based on the FINE CONE designed by Acoustic expert, Peter Larsen.
This design follows strict discipline in speaker designs to achieve perfect linear frequency response curve. Ideal home theater system in all natural wood finish.
Uncolored audio, precise position, and high resolution with Microlab own eAirbass technology
Features:
Powerful 5.1 surround subwoofer system with full range acoustic production and cabinet satellites
eAirbass design, Microlab own proprietory technology - Bass with natural depth and range
6.5" woofer system for deep vocal and bass effects. All magnetically shielded
Designed by Denmark acoustic expert, Peter Larsen V12 FineCone technology with perfect linear response
Individual amplifier unit with full front controls and includes wireless remote control
Technical Specifications:
Amplifier:
Output power: 84 Watt RMS
Power distribution: 12 Watt x 5 + 24 Watt
Harmonic distortion: < 0.3% 1 W 1 kHz
Frequency response: 30 Hz - 20 kHz
Signal/Noise ratio: > 70 dB
Separation: > 40 dB
Input sensitivity: 430 mV
Nominal impedance: 4 ohm
Speakers:
Tweeter driver type: 2.5" x 5
Tweeter rated power: 10 Watt
Subwoofer driver type: 6.5" - eAirbass
Subwoofer rated power: 40 watt
Interfaces:
Output: 6RCA sockets
Input: 6RCA sockets
Radio:
FM 87 mHz - 108m Hz
AM 522 - 1611 kHz EU, 530 - 1720 kHz South America & USA
Power:
Power supply: AC220 V - 240 V, 50 Hz, 380 mA
Fuse: T800mAL250V
Includes remote control
Package Contents:
Microlab FC730 subwoofer
Microlab FC730 satellites x 4
Microlab FC730 center speaker
3.5mm - 2RCA audio cable x 3
2RCA - 2RCA audio cable
User manual
5.1+1 system
5.1+1 system is a perfect acoustic effect could be reached if connected to the audio source with AC-3 or DTS decoder. -
6.5" subwoofer
6.5" subwoofer unit made of dual Sr Magnet system blazes the trail in the use of costly low-Q value, long-stroke program design, having the low-frequency quality of quick and high resolution. -
EAirbass
Departing from traditional bass technology, eAirbass creates no distortion when enhancing bass. With airflow passage design, it delivers clearer sound with an extended frequency range. The use of electronic control technology enables a precise bass signal selection for enhanced bass delivery and crystal clear high notes reproduction. -
Design for music
The ultimate aim of Microlab R&D system is to inherit and carry forward the European musical culture style. To do this, all designs must be music-oriented and sourced from music and art. Having Microlab, you can enjoy European musical taste.
- Microlab FineCone FC730 - speaker system - for PC
- Product Type
- V12 - speaker system - for PC - 5.1-channel
- System Components
- 5 speakers, subwoofer, amplifier
- Speaker Type
- Active
- Nominal Output Power (Total)
- 84 Watt
- Frequency Response
- 30 - 20000 Hz
- Amplifier
- External
- Speaker System Details
- 4 x satellite speaker 12 Watt - 140 - 20000 Hz , 1 x subwoofer 24 Watt - 30 - 140 Hz , 1 x centre channel speaker 12 Watt - 140 - 20000 Hz
- Product Type
- Speaker system - for PC - 5.1-channel
Speaker System
- Series
- V12
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 84 Watt
- 30 - 20000 Hz
- Total Harmonic Distortion
- 0.3%
- Magnetic Shield
- Amplifier
- External
- Speakers Included
- 4 x satellite speaker - 12 Watt - 140 - 20000 Hz - wired , 1 x subwoofer - 24 Watt - 30 - 140 Hz - wired , 1 x centre channel speaker - 12 Watt - 140 - 20000 Hz
- Driver Details
- Satellite speaker: full-range driver - 2.5"
- Driver Details (2nd speaker)
- Subwoofer: subwoofer driver - 6.5" , Centre channel speaker: full-range driver - 2.5"
- Included Accessories
- Remote control
- Remote Control
- Remote control - infrared
- Power Source
- AC power adapter
- Dimensions (WxDxH) / Weight Details
- Satellite speaker: 11.2 cm x 13.5 cm x 19.5 cm , Subwoofer: 24.1 cm x 25.9 cm x 28 cm , Centre channel speaker: 26.5 cm x 13.5 cm x 11.2 cm , Amplifier: 8.9 cm x 30.5 cm x 25 cm
