Powerful high fidelity 2.1 subwoofer speaker system with DSP technology
Designed elegantly, this system fits ideally in your living room and even the studies
Using DSP technology lets you get precise sound from its original source by accurately converting analog to digital signal
Thus you get the best full range sound with minimum distortion
Powerful subwoofer with built-in amplifier that gives you unprecedented vocal and depth in bass frequencies
The subwoofer designed with bass reflex tunnel for efficient woofer movements and complete low frequencies production
Two powerful satellites with high quality tweeters and uncolored acoustic production
Wireless RF remote control with circular volume turntable knob for complete level controls
The remote control uses radio frequency for 360-degree all round use without signal being blocked
Technical Specifications
Amplifier specs:
Output power - 40, Watt RMS
Power distribution - 10x2 + 20, Watt
Frequency response - 50-18 000, Hz
Signal/Noise ratio - 75, dB
Separation - 50, dB
Speakers specs:
Tweeter driver type - 2.5,
Tweeter rated power - 15, Watt
Bass driver type - 5,
Bass rated power - 30, Watt
Material - MDF/plastic
Remote control - 1
Interfaces:
Output - 2RCA
Input - 3.5 mm stereo
Dimensions
Satellites - 83x194.5x86.5, mm
Subwoofer - 220x226x246.5, mm
Product Net weight - 4.6, kg
- Microlab FineCone FC20 - speaker system - for PC
- Product Type
- Speaker system - for PC - 2.1-channel
- System Components
- 2 speakers, subwoofer
- Speaker Type
- Active
- Nominal Output Power (Total)
- 40 Watt
- Frequency Response
- 50 - 18000 Hz
- Amplifier
- Integrated
- Speaker System Details
- 2 x satellite speaker 10 Watt 4 Ohm , 1 x subwoofer 20 Watt 8 Ohm
- Image Colour Disclaimer
- The displayed product image may be a different colour
- 4.6 kg
- Product Type
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 40 Watt
- 50 - 18000 Hz
- Total Harmonic Distortion
- 0.5%
- Amplifier
- Integrated
- Speakers Included
- 2 x satellite speaker - 10 Watt - 4 Ohm - wired , 1 x subwoofer - 20 Watt - 8 Ohm - wired
- Driver Details
- Satellite speaker: high/midrange driver - 2.5"
- Driver Details (2nd speaker)
- Subwoofer: subwoofer driver - 5"
- Connector Type
- Audio output (RCA x 2) , Audio line-in (mini-phone stereo 3.5 mm) , DC power input
- Included Accessories
- AC power adaptor, audio cable, RF remote control
- Remote Control
- Remote control
- Power Source
- AC power adapter
- 4.6 kg
- Dimensions (WxDxH) / Weight Details
- Satellite speaker: 8.3 cm x 8.65 cm x 19.45 cm , Subwoofer: 22 cm x 24.65 cm x 22.6 cm
