Powerful 2.1 subwoofer system with HC2D and DSP advanced technology
Listen to clear and accurate reproduction sound with this powerful 2.1 subwoofer system at close distance. Nowadays, most of us spent lots of time at our desks but most speakers are optimized for listening at a distance. Utilizing advanced Microlab own HCD technology, we have created an entirely new listening experiences. Now you can listen to clear sound reproduction from speakers designed for short spaces such as desktop and counters. Also with latest digital signal processor to process your source signal such as from CD/DVD, PC/notebook into uncoloured and crystal clear sound. Advanced satellite speakers designed without enclosures for extreme clarity sound. Speakers without enclosures do not have the inherent harmonic distortions, and vibrations that affects the original sound signal. Tweeter and Midrange drivers arranged in tandem within the satellite for perfect harmony. Powerful amplifier built into the subwoofer for strong and bass delivery. Deep vocals and depth with carefully designed bass reflex tunnel.
Connects to most media players and PC/Notebook via 3.5 mm stereo plug. Includes a wireless remote control for quick volume and bass level adjustment.
Crystal clear sound in full range resolution with HC2D technology
Powerful amplifier built into subwoofer
2.1 subwoofer system with 2-way stereo satellites
Digital signal processor for clearer sound reproduction
Deep bass punch with 5" woofer driver
0.75" tweeter and 4" midrange arranged in tandem for perfect clear sound
Connects to most media player with 3.5 mm stereo plug
Wireless remote control with volume and bass level adjustments
Spec:
Amplifier
Output power: 54 Watt RMS
Power distribution: 12 Watt x 2 + 30 Watt RMS
Harmonic distortion: < 0.5% 1 W 1 kHz
Frequency response: 40 Hz - 20 kHz
Signal/Noise ratio: > 80 dB
Separation: > 45 dB
Speakers
Tweeter driver type: 0.75"
Tweeter driver rated power: 10 Watt 6 Ohm
Midrange driver type: 4"
Midrange driver rated power: 15 Watt 8 Ohm
Woofer driver type: 5"
Woofer driver rated power: 30 Watt 4 Ohm
Output: 2RCA
Input: 3.5 mm stereo
Power input: DC
Remote control: wireless
DC power input: 20 V 3000 mA
AC power adapter: AC 100 V - 240 V
Dimensions
Satellite speaker dimension: 159(W) x 230(H) x 103(D) mm
Subwoofer speaker dimension: 218(W) x 218(H) x 289.5(D) mm
Wireless remote control dimension: 77(Dia) x 30.3(H) mm
Product net weight: 5.6 kg
- Microlab FineCone FC50 - speaker system - for PC
- Product Type
- Speaker system - for PC - 2.1-channel
- System Components
- 2 speakers, subwoofer
- Speaker Type
- Active
- Nominal Output Power (Total)
- 54 Watt
- Frequency Response
- 40 - 20000 Hz
- Amplifier
- Integrated
- Speaker System Details
- 1 x subwoofer 30 Watt , 2 x satellite speaker 12 Watt
- Black
- 5.6 kg
- Product Type
- Enclosure Colour
- Black
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 54 Watt
- 40 - 20000 Hz
- Signal-To-Noise Ratio
- 80 dB
- Total Harmonic Distortion
- 0.5%
- Amplifier
- Integrated
- Speakers Included
- 1 x subwoofer - 30 Watt - wired , 2 x satellite speaker - 2-way - 12 Watt - wired
- Driver Details
- Subwoofer: subwoofer driver - 5"
- Driver Details (2nd speaker)
- Satellite speaker: mid-range driver - 4" , Satellite speaker: tweeter driver - 0.75"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- AC power adaptor, audio cable, RF remote control
- Power Source
- AC power adapter
- 5.6 kg
- Dimensions (WxDxH) / Weight Details
- Satellite speaker: 15.9 cm x 10.3 cm x 23 cm , Subwoofer: 21.8 cm x 28.95 cm x 21.8 cm
- Shipping Width
- 36.6 cm
- Shipping Depth
- 31.6 cm
- Shipping Height
- 36.8 cm
- Shipping Weight
- 6.7 kg
