Matrox TripleHead2Go is an external multi-display upgrade for notebooks and desktop computers. Ideal for professionals requiring extensive desktop space for maximum productivity increases and gamers wanting a totally immersive experience, this small box lets you run different applications on each display or view one application across up to three monitors. Available in digital or analog editions.
- Matrox Graphics eXpansion Module TripleHead2Go - Digital Edition - video converter
- Video converter
- Max Resolution
- 1920 x 1080
- Max Monitors Supported
- 3
- 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x DVI-D input - 24+1 pin digital DVI , 3 x DVI-I output - 24+5 pin combined DVI , 1 x USB
- 11.3 cm x 14 cm x 2.8 cm
- 2-year warranty
- Video converter
- Max Resolution
- 1920 x 1080 at 50 Hz
- 3
- USB powered
- OS Required
- Linux, Apple MacOS X 10.5 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
- Additional Requirements
- USB port
- Cables Included
- 1 x VGA cable - 61 cm , 1 x DVI cable - 61 cm , 1 x USB cable
- 11.3 cm
- 14 cm
- 2.8 cm
- Limited warranty - 2 years
