The low-profile Matrox Millennium P690 Plus LP PCI offers 256MB of graphics memory, full DualHead support for two digital or analog monitors at high resolution and pristine image quality, and can be upgraded (via a Quad-HD15 cable) to drive four analog monitors. With ultra-low power consumption, fanless cooling, and unified display drivers for easy deployment across multiple systems, the P690 Plus LP PCI is suitable for a wide range of professional applications. This graphics card builds upon the reliability, stability, and features of the proven Millennium P-Series product line, making it an ideal choice for use in long-life environments.
- Matrox Millennium P690 Plus LP PCI - graphics card - MGA P690 - 256 MB
- Graphics card - low profile
- Bus Type
- PCI
- Graphics Engine
- Matrox MGA P690 - up to
- Memory
- 256 MB DDR2
- Max Resolution
- 2048 x 1536
- 1 x DVI-I - 60 PIN LFH , 2 x DVI-I - 24+5 pin combined DVI (on supplied cable) , 2 x VGA - 15 pin HD D-Sub (HD-15) (with adapter)
- 16.8 cm x 6.5 cm
- 3-year warranty
- Bus Type
- PCI
- Graphics Engine
- Matrox MGA P690
- Max Resolution
- 2048 x 1536
- Size
- 256 MB
- Technology
- DDR2 SDRAM
- OS Required
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows Vista, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions)
- Included Accessories
- Low-profile bracket
- Cables Included
- 1 x DVI cable - 30 cm , 2 x DVI-VGA adapter
- Software Included
- Matrox PowerDesk, Driver
- CSA, VCCI, EMC, FCC, RoHS, WEEE
- 16.8 cm
- 6.5 cm
- Limited warranty - 3 years
