The Matrox M9148 LP PCIe x16 four monitor graphics card renders pristine images across four DisplayPort monitors at resolutions up to 2560 x 1600 per output for an exceptional multi-monitor user experience. With 1 GB of memory and advanced desktop management features such extending the Windows Taskbar to span multiple displays and support of independent or stretched modes, the M9148 drives business, industrial, and government applications with extraordinary performance. Its low-profile form factor makes it easy to integrate into a wide variety of systems, it offers optimal Windows Vista Aero support (WDDM mode), and it can be paired with another M9148 graphics card to support up to eight DisplayPort monitors from a single system.
High-resolution four DisplayPort monitor support
It is up to 2560 x 1600 per output. -
Native PCI express x16 performance
It is maximum bandwidth to ensure best performance. -
1 GB of memory
For enhanced performance in demanding multi-monitor applications. -
Low-profile form factor
To fit in a wide variety of systems; includes bracket for full-height ATX form factor. -
Passive cooling and low power consumption
Fanless design eliminates noise and increases product reliability. -
Joined graphics card mode
Insert two M-series cards into the same system to drive even more monitors. -
Wide enterprise flexibility
It is unified driver package compatible with other Matrox products.
- Matrox M9148 - graphics card - M9148 - 1 GB
- Graphics card - low profile
- Bus Type
- PCI Express x16
- Graphics Engine
- Matrox M9148
- Memory
- 1 GB
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 1920 x 1200 / DisplayPort: 2560 x 1600
- Max Monitors Supported
- 4
- Interfaces Details
- 4 x Mini DisplayPort , 4 x DisplayPort - with adapter , 4 x DVI-D (dual link) - with adapter
- API Supported
- OpenGL 2.0
- 16.8 cm 6.9 cm
- Microsoft Certification
- Windows 8 Compatible
- 3-year warranty
- Bus Type
- PCI Express x16
- Graphics Engine
- Matrox M9148
- Max Resolution
- 2560 x 1600
- 4
- API Supported
- OpenGL 2.0
- Fanless heatsink
- Size
- 1 GB
- OS Required
- Linux, Microsoft Windows Server 2003, Microsoft Windows Vista (32/64 bits), Microsoft Windows Embedded Standard 7, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows Server 2012 (32/64-bits)
- Included Accessories
- Low-profile bracket
- Software Included
- Matrox PowerDesk
- This product has been tested to meet all of the technical requirements to be Windows 8 Compatible.
- RoHS, WEEE
- 16.8 cm
- 6.9 cm
- Limited warranty - 3 years
