Manta 42" LED 3D Full HD TV
Quicklinx: 7XQXWS00 Mfr#: LED4201 3D
  • 1080p
The Manta 42-inch Passive 3D Widescreen LED TV supplied with 4 Sets of 3D Glasses (1 are clip-on) brings you the experience of 3D Cinema in your own home.
Connect to either a 3D Blu Ray Player,3D Games Console,Sky+ or Virgin HD+ 3D device to enjoy the full experience of 3D TV (sold separately).
The Manta 42-inch also features 2D to 3D conversion to deliver a pseudo 3D experience via standard Freeview Digital TV or DVD/ Blu Ray. The Manta 42-inch is Full HD1080P compatible ideal for getting the best out of a High Definition Blu Ray player, Full HD games console or other HD device.
Features up to 50 digital Freeview channels & up to 24 radio stations without the need for subscription.
High quality 3D LED screen is flicker free, thus greatly reducing fatigue of your eyes. it also features high brightness & contrast and wide view. Extreme responsiveness greatly reduces blurred pictures in motion.
Having high quality speakers, which will give you audiovisual enjoyment.
Having many connectors, you may directly connect your DVD, Blu-Ray player etc. The product can be used as a computer monitor with VGA and HDMI connectors. Also it can be used as a TV with the built-in DVB-T tuner.
Much faster response time will completely eliminate picture shadows, film and game playing may be more fluent.
Manta TV's come with a Power Supply Switch for safe power cut-off to save energy.
The Manta 42-inch is VESA wall mounting compatible.
Box Contains Manta LED4201 42" 3D LED TV, 4 Pairs of Passive 3D Glasses (1 are clip-on), TV Stand, Remote Control & Batteries, Instructions
Supports 3D video player function, bringing you true-to-life 3D scene and vivid experience.
Compatibility with 2D/3D display allows you to freely switch from 2D to 3D, and vice versa.
Wider viewing angle, higher brightness, higher contrast, lower consumption.
Intelligent image mode and sound mode can offer you intelligent audiovisual effect.
Built-in, latest digital comb filter, which makes image more clear. The internal 3D De-Interlace technique can totally eliminate the screen dithering caused by interlace signals.
Timing functions, you can set time to turn off. It will be also be turned off when no signal is present.
Auto-setup function help you set the image to performance in several seconds in VGA mode.
Auto color balance adjustment technology takes your machine to the best color setting for all different kinds of display adapters in VGA mode.
Automatic denoise technique can greatly eliminate background noise caused by menu interference and the noise caused by weak signals so as to make the picture on the screen clearer. Support USB interface.
Support for H.264 FULL HD receiver and supports PVR functionality.
Diagonal Size (inches)
42 in
LED
HD Standard
1080p (FullHD)
HDMI Inputs
3
HDMI, SCART, S-Video
