Support 3D video player function, bringing true-to-life 3D scene and vivid experience. Four set of glasses included.
Compatibility with 2D/3D display allows you to freely switch from 2D to 3D, and vice versa.
High quality 3D LCD screen is flicker free greatly reducing fatigue of your eyes.
It also features high brightness & contrast and wide view. Extremely responsiveness greatly reduces blurred pictures in motion.
High quality speakers, which will give you audiovisual enjoyment.
Having many connectors, you may directly connect your DVD, Blu-Ray or Media Player etc.
The product can be used as a computer monitor with VGA and HDMI connectors. Also it can be used as a TV using the inbuilt DVB-T tuner.
Much faster response time will completely eliminate picture shadows, making film and game playing more fluent.
Wider viewing angle, higher brightness, higher contrast, lower consumption.
Intelligent image mode and sound mode can offer you intelligent audiovisual effect.
Latest digital comb filter, which makes the image more clear.
The internal 3D De-Interlace technique can totally eliminate screen dithering caused by interlace signals.
Auto-setup function help you set the image to best performance in several seconds in VGA mode.
Auto color balance adjustment technology adjusts settings to the best color setting for all different kinds of display adapters in VGA mode.
Automatic de-noise technique can greatly eliminate background noise caused by menu interference and the noise caused by weak signals so as to make the picture on the screen clear.
- Diagonal Size (inches)
- 32 in
- Technology
- LCD
- HD Standard
- 720p
- HDMI Inputs
- 2
- Interface
- SCART
- Aspect Ratio
- 16:9
- Contrast Ratio
- 12,000:1
- Dimensions & Weight / Depth
- 101 mm
- Dimensions & Weight / Height
- 555 mm
- Dimensions & Weight / Width
- 782 mm
- Freeview Bult In
- Freeview
- Native Resolution
- 1,366 x 768
- Product Line
- Manta
- Television / Type
- 3D LCD TV
- Tuner Type
- 1x digital
- TV Tuner / Type
- DVB-T
