Experience every jolt, bump and shudder with Mad Catz' officially licensed Wireless Force Feedback Racing Wheel for Xbox 360. Force feedback makes the wheel come alive as you feel each and every nuance of the road. Rev up the throttle and when the tires start to slip, powerful rumble technology kicks in to provide the response needed to make race-critical adjustments. Complete with a sequential stick shift and true-to-life gas and brake pedals, all the intensity of a race comes to the comfort of your home and shifts your racing into top gear.
Just like in a real car, the wheel reacts to what is happening on the racetrack and provides resistance when you turn. Enhance your gaming performance as you get in tune with the road and experience shifts in weight and variances in surface conditions.
Force Feedback provides realistic resistance
Just like in a real car, the wheel reacts to what is happening on the racetrack and provides resistance when you turn. Enhance your gaming performance as you get in tune with the road and experience shifts in weight and variances in surface conditions. -
Feel the game with Vibration technology
Feel what's happening whenever your vehicle takes damage or changes terrain. Drive over the racetrack's edge or trade paint with the competition and Vibration technology kicks in to enhance realism. -
Powerful wireless connectivity
Boasting a wireless range of 40 feet, enjoy lag-free gameplay from anywhere in the room. -
Full rubber grip points
Ideal for extended races when comfort matters most, take hold of the full rubber grip points for precise steering and utmost control. -
Part-metal construction
Coupling a distinguished design with a durable build, the part-metal construction increases longevity while delivering appealing aesthetics. -
Interchangeable gear shift
Whether you're a left- or right-handed racer, an interchangeable gear shift accommodates. Simply screw it into the side of the wheel which best suits your racing style. -
Non-slip pedal set
Reserve drifting for the racetrack - hit the gas or slam on the brakes and their non-slip surface helps the pedals stay put. Give your inactive foot a supportive break with the detachable foot rest. -
Integrated Xbox live headset port
When you're ready to pit your racing skills against online competitors, just plug directly into the integrated headset port to gain control of all your conversations.
- Mad Catz Wireless Force Feedback Racing Wheel with Vibration Technology - wheel and pedals set - wireless
- Product Type
- Wheel and pedals set
- Connectivity Technology
- Wireless
- Headset port
- 2-year warranty
- Designed For
- Microsoft Xbox 360
- Product Type
- Wireless
- Max Operating Distance
- Up to 12.2 m
- Headset port
Game Controller (1st) Details
- Wheel
- Controls
- Gear shift lever, gear shift paddles
- Force feedback, interchangeable gear shift, rubber side grips, vibration
Game Controller (2nd) Details
- Pedals
- Detachable foot rest, non-slip surface
- Limited warranty - 2 years
- Designed For
