You've got enough power to fill the room with bold, dynamic sound. A subwoofer with a 4-inch driver delivers deep lows for rich bass you can feel.
An RCA jack and two 3.5 mm auxiliary inputs let you easily connect up to 3 devices at the same time: PC, DVD player, game console, smartphone, and more.
40 watts (RMS) of power
You've got enough power to fill the room with bold, dynamic sound. -
Down-firing subwoofer
A subwoofer with a 4-inch driver delivers deep lows for rich bass you can feel. -
Multiple connectivity
An RCA jack and two 3.5 mm auxiliary inputs let you easily connect up to 3 devices at the same time: PC, DVD player, game console, smartphone, and more. -
Convenient control pod
Power, volume, and bass controls are within your reach with the wired control pod. -
Small size, big versatility
Optimize the look and sound of your setup with the compact, versatile design. Satellites sit on metal stands that can tilt up or down. Or if you prefer, mount them to the wall. -
Logitech FDD² technology
Enjoy fuller, richer sound thanks to Logitech's patented Frequency Directed Dual Drivers (FDD²) satellite technology.
- Logitech Z-553 - speaker system - for PC
- Product Type
- Speaker system - for PC - 2.1-channel
- System Components
- 2 speakers, subwoofer
- Speaker Type
- Active
- Nominal Output Power (Total)
- 40 Watt
- Frequency Response
- 55 - 17000 Hz
- Amplifier
- Integrated
- Speaker System Details
- 2 x satellite speaker 10 Watt 4 Ohm , 1 x subwoofer 20 Watt 8 Ohm
- 2-year warranty
- Product Type
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 40 Watt
- 55 - 17000 Hz
- Amplifier
- Integrated
- Controls
- Power on/off, volume, bass
- Speakers Included
- 2 x satellite speaker - 10 Watt - 4 Ohm - wired , 1 x subwoofer - 20 Watt - 8 Ohm - wired
- Driver Details
- Satellite speaker: full-range driver - 2" - Frequency Directed Dual Driver (FDD2)
- Driver Details (2nd speaker)
- Subwoofer: subwoofer driver - 4"
- Connector Type
- 2 x audio line-in (mini-phone stereo 3.5 mm) , Audio line-in (RCA x 2)
- Included Accessories
- Audio cable, remote control
- Remote Control
- Remote control - cable
- Power Source
- AC power adapter
- Dimensions (WxDxH) / Weight Details
- Satellite speaker: 9 cm x 13.7 cm x 16 cm , Subwoofer: 38.1 cm Diameter 16 cm
- Limited warranty - 2 years
