Turn your favorite speakers into a wireless sound system. Logitech® Wireless Speaker Adapter for Bluetooth® audio devices uses Bluetooth wireless to stream music or other audio from your smartphone or tablet.
Now you can listen to all the music, movies and games on your Laptop, iPhone, iPad or Android phone the way they were meant to be heard--in full, detailed sound through your home speakers. Just plug this sleek little adapter into your powered speakers or home theater system. It's that easy to turn your speakers into a wireless sound system for your Bluetooth-enabled smartphone or tablet.
Bluetooth connectivity
Stream stereo audio instantly from any Bluetooth smartphone or tablet. Your mobile device stays mobile, and you have the freedom to move around with it.
Wireless audio
Listen to music or other audio from your smartphone or tablet on your favorite speakers--with better sound quality than you can get from built-in speakers.
Simple setup
Logitech software for Bluetooth configures your Logitech Wireless Speaker Adapter to work with your smartphone or tablet, so it's easy to set up and use.
Freedom of choice
You have the flexibility to use almost any pair of powered speakers you like. Attach Logitech Wireless Speaker Adapter for Bluetooth audio devices to your speakers using standard analog RCA or 3.5 mm jacks.
Compact design
The sleek styling looks good on a shelf or can be hidden away discreetly. The choice is yours.
Box Contents:
Wireless audio streamer
Power cable
RCA to 3.5 mm audio cable
User documentation
Stream stereo audio instantly from any Bluetooth smartphone or tablet. Your mobile device stays mobile, and you have the freedom to move around with it. -
Wireless audio
Listen to music or other audio from your smartphone or tablet on your favorite speakers - with better sound quality than you can get from built-in speakers. -
Simple setup
Logitech software for Bluetooth configures your Logitech Wireless Speaker Adapter to work with your smartphone or tablet, so it's easy to set up and use. -
Freedom of choice
You have the flexibility to use almost any pair of powered speakers you like. Attach Logitech Wireless Speaker Adapter for Bluetooth audio devices to your speakers using standard analog RCA or 3.5 mm jacks. -
Compact design
- Logitech Wireless Speaker Adapter - Bluetooth wireless audio receiver
- Product Type
- Package Content
- AC power adaptor, audio cable, Bluetooth audio receiver
- Localisation
- United Kingdom
- 2-year warranty
- Product Type
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP)
- Package Content
- Localisation
- United Kingdom
- 2 years
