AI-powered tabletop camera that delivers a more equitable video conferencing experience.
TAKE A SEAT AT THE TABLE
AI-powered meeting room camera that helps remote attendees feel like they're actually seated at the table -
FRONT AND CENTER
Add a tabletop perspective to your front-of-room camera to deliver a better, more inclusive hybrid meeting experience -
TWO VIEWPOINTS. A BETTER PERSPECTIVE
A new approach combines Sight at the table with the front-of-room video bar to show the best angle -
CAPTURE THE ACTION
Sight uses video and AI to detect and accurately frame participants, with 315° field of view -
DESIGNED FOR DIFFERENT SPACES
Created for medium to large collaboration spaces, Sight extends the capabilities of the front-of-room camera to pick up on conversations and nonverbals around the room -
CLEAR AUDIO. CLEAR VIDEO. CLEAR CONTROLS
With 4K cameras and 7 beamforming mics, Sight captures conversation and nonverbals clearly. Indicator lights and privacy shade allow for clear signaling and status control -
CLEAN AND SECURE INSTALL
Easily install and secure Sight with the included mounts. Keep tables clean and cables plugged in with integrated cable management -
QUICK TO DEPLOY. SIMPLE TO MANAGE
SIMPLE TO MANAGE Easily manage your Logitech video collaboration devices with Logitech Sync. Monitor room health, deploy updates, and modify settings all from a single cloud-based platform. And with Sync Insights, you can see how meeting spaces are utilized over time. LEARN MORE ABOUT LOGITECH SYNC -
OUR COMMITMENT TO SUSTAINABILITY
Logitech is committed to creating a more sustainable world, using lower carbon materials like post-consumer recycled plastics for our products whenever possible. We are actively working to minimize our environmental footprint and accelerate the pace of social change. LEARN MORE ABOUT LOGITECH'S SUSTAINABILITY INITIATIVES
- Logitech Sight - conference camera
- Conference camera - fixed
- Audio
- Yes: built-in seven omni-directional beam-forming microphones
- Camera Mount Type
- Tripod mount, grommet mount, table mount
- White
- Connectivity Technology
- Wired
- Camera
- Frame Rate (max)
- 60 frames per second
- Video Modes
- 4K
- Focal Length
- 1.87 mm
- Focus Adjustment
- Automatic (min distance 50 cm)
- Software Certification
- Optimised for Google Meet, Certified for Zoom Rooms, Certified for Microsoft Teams Rooms
- Voltage
- PoE Plus
- LED indicator, dual lens, Acoustic Echo Cancellation (AEC), microphone noise suppression technology, Voice Activity Detector (VAD), dual cameras, intelligent multi-participant framing, AI-powered, up to 2.3 m audio pickup, 315° field of view (using AI), microphone mute control
- 2-year warranty
- Environmental Parameters (operating)
- 0 °C - 40 °C; 10 - 90% RH (non-condensing) relative humidity
- Conference camera
- Audio Support
- Camera Mount Type
- Wired
Camera
- Colour - fixed
- Video Modes
- 4K
- Frame Rate (max)
Lens Construction
- Focal Length
- 1.87 mm
- Focus Adjustment
- Automatic
- Min Focus Distance
- 50 cm
- Horizontal Field of View (degree)
- 180
- Vertical Field of View (degree)
- 97
- Diagonal Field of View (degree)
- 180
- Ports
- 3 x LAN/power - RJ-45
- Included Accessories
- Sight dongle, mic pod dongle, privacy shade, grommet mount, table mount, tripod mount
- IP57, CarbonNeutral, IEEE 802.3at
- White
- Power Requirements
- PoE Plus
- OS Required
- Apple MacOS, Windows 10 / 11 or later
- Limited warranty - 2 years
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 10 - 90% RH (non-condensing)
