Logitech Pebble M350 Wireless Mouse - Graphite
Quicklinx: G7X6WS00 Mfr#: 910-005718
Recommended Use: Leisure
Type: Mouse
Wired / Wireless: Wireless
Colour: Graphite
Compatibility: PC
£18.99 ex VAT
£22.78 inc VAT
Make any space minimalist, modern, and silent with Logitech Pebble - the portable mouse that fits your curated lifestyle and goes wherever life takes you. The smooth organic shape fits in your pocket, bag, and feels great in your hand.
  • Logitech Pebble Wireless Mouse M350
    Minimalist. Modern. Silent
  • COMFORTABLE SET-UP
    The keyboard's extra-small footprint lets you place your mouse closer for less arm reaching and better body posture. The scooped, low-profile scissor keys give you a fluid, quiet, laptop-like typing experience.  While the slim, pebble mouse fits naturally in the palm of your hand for a lovely and comfy duo
  • WHISPER-QUIET WORK
    This duo is designed for peace and quiet. Logitech Pebble's silent technology gives you the same click feel you love with about 90% less noise Sound level comparison between Logitech Pebble M350 and Logitech M170. Left click dBA measured by an independent lab at 1m. , even the wide rubber scroll wheel glides in silence.  The low-profile keyboard keys give you a fluid, comfortable and whisper-quiet typing experience, so you can work in a cafe, library, or on your bed covers without disturbing anyone around you
  • LONG BATTERY LIFE
    The keyboard and mouse both feature a battery-saving sleep mode that kicks in when you're taking a break-to make them last even longer. Logitech Pebble: 18M battery life K380 Keyboard: 24M battery life
  • CLICK AND SCROLL IN SILENCE
    Work in a cafe, library, or even a crowded train without disturbing anyone around you. You'll get the same click feel you love, but make about 90% less noise. Sound level comparison between Logitech Pebble M350 and Logitech M170. Left click dBA measured by an independent lab at 1m. Even the wide rubber scroll wheel glides in silence
  • CONNECT THE WAY YOU LIKE
    Connect to your computer, laptop or tablet via Bluetooth or the tiny USB receiver -stored in the magnetic cover of the mouse- and never worry about annoying drop-offs or lag up to a 10m range Wireless range may vary based on environmental and computing conditions. . -Windows , macOS, Chrome OS , iPadOS
  • ORGANIC SHAPE, NATURAL FIT
    Logitech Pebble M350 has been designed to be extra slim, while still fitting naturally in the palm of your hand. The soft rounded sides are so comfortable, you'll never want to let it go
  • THE RIGHT COLOR FOR YOU
    Choose Logitech Pebble M350 in off-white, graphite, blue or rose pink to perfectly match the rest of your accessories
  • WORK WHEREVER LIFE TAKES YOU
    Logitech Pebble M350 tracks fast and accurately whether you use it on a table at your favorite coffee shop or directly on your bed covers
  • GO LONGER BETWEEN BATTERIES
    18-month battery Battery life may vary based on user and computing conditions. Battery included. life means you don't have to worry about losing power. Logitech Pebble M350 automatically goes into battery-saving sleep mode when you're taking a break
  • HOW TO SETUP
    Just pull the sticker tab and your Logitech Pebble M350 will automatically turn on. As it's ready to be connected, the status light flashes green and blue
  • Step 1
Logitech Pebble M350 - mouse - Bluetooth, 2.4 GHz - graphite
Mouse
Wireless - Bluetooth, 2.4 GHz
Graphite
5.9 cm x 10.7 cm x 2.65 cm
100 g
Wireless Receiver
Nano USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
High Definition Optical Technology
AA type
Linux Kernel 2.6 or later, Google Chrome OS, Microsoft Windows 7 / 8 / 10 or later, Android 5.0 or later, Apple MacOS X 10.10 or later
Mouse
Wireless Receiver
5.9 cm
10.7 cm
2.65 cm
100 g
Graphite
Input Device
Wireless
Bluetooth, 2.4 GHz
Max Operating Distance
Up to 10 m
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
1 AA battery
AA type
Run Time (Up To)
18 months
Type: Mouse
Colour: Graphite
Compatibility: PC
Brand: Logitech
