A classic, lower-profile mouse with high-definition optical tracking that will comfort purchasers and professionals alike.
High-definition optical tracking
You'll enjoy responsive and smooth cursor control on a variety of surfaces with the high-definition optical tracking (1000 dpi).
Comfortable, ambidextrous design
The comfortable, lower-profile shape feels good in either hand--even after a long day of work.
Side-to-side scrolling plus zoom
The power is in your hands. You can scroll side-to-side in documents or zoom in and out of photos and spreadsheets with a flick of your finger.
Easy-scrolling wheel
The grid design of the scroll wheel is comfortable and easy to use.
You'll enjoy responsive and smooth cursor control on a variety of surfaces with the high-definition optical tracking (1000 dpi) -
The power is in your hands. You can scroll side-to-side in documents or zoom in and out of photos and spreadsheets with a flick of your finger -
The comfortable, lower-profile shape feels good in either hand-even after a long day of work -
The grid design of the scroll wheel is comfortable and easy to use -
Smooth operator
You're in control with smooth, responsive optical tracking that moves the cursor just where you want it -
Helping hand
A mouse everyone can use. The ambidextrous, lower-profile shape keeps you comfortable hour after hour -
It gets around
You can get more done, faster with side-to-side scrolling plus zoom moving you through documents
- Logitech Optical Mouse RX250 - mouse - PS/2, USB - black
- Mouse
- Connectivity Technology
- Wired - PS/2, USB
- Black
- Orientation
- Right and left-handed
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Tilt Wheel Plus Zoom, scrolling wheel (4-way)
- Cables Included
- 1 x USB cable - integrated , 1 x mouse adapter - external
- OS Required
- Microsoft Windows Vista / 2000 / XP
- Package Type
- OEM
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Mouse
- Orientation
- Black
Input Device
- Wired
- Interface
- PS/2, USB
- Optical
- Buttons Qty
- 3
- 1000 dpi
- 1 x USB - 4 pin USB Type A , 1 x mouse - generic - 6 pin mini-DIN (PS/2 style)
- Cables Included
- Package Type
- OEM
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 3 years
