FEATURES
Designed for users with advanced or specialized workflow needs -
KEY FEATURES
ALL-DAY COMFORT DESIGN FEATURES THAT MATTER The keyboard's solid design uses a single metal plate for stability and quieter typing. While the perfectly-crafted full-size mouse contours to the shape of the hand for easy access to the buttons and scroll wheel. The included MX Palm Rest features a premium cushioned surface, designed as an ideal companion providing all-day comfort -
FEATURES THAT DELIVER
Full-size keyboard with Smart backlighting. Hand proximity sensors turn the backlighting on and ambient light sensors adjust backlight brightness to better manage battery life
- Logitech MX Keys Combo for Business - keyboard and mouse set - QWERTY - UK - graphite Input Device
- Keyboard and mouse set
- Backlit
- Interface
- Bluetooth LE
- Wireless Receiver
- Logitech Logi Bolt USB receiver
- Connectivity Technology
- Wireless
- Localization and Layout
- QWERTY UK
- Keys Qty
- 108
- Hot Keys Function
- Multimedia, mute, Easy-Switch, PerfectStroke
- Keys Style
- Scissors
- Numeric Keypad
- Pointing Device
- Mouse - wireless - optical - right-handed
- Buttons Qty
- 7
- Graphite
- 2-year warranty
- Backlit
- Interface
- Bluetooth LE
- Max Operating Distance
- Up to 10 m
- Wireless Receiver
- Dimensions (WxDxH) / Weight
- Keyboard: 43.02 cm x 13.163 cm x 2.05 cm / 810 g , Mouse: 8.43 cm x 12.49 cm x 5.1 cm / 141 g , Palm rest: 42 cm x 6.4 cm x 0.8 cm / 180 g
- Wireless
- Keyboard Name
- Logitech MX Keys for Business
- Keys Qty
- 108
- Hot Keys Function
- Keys Style
- Scissors
- QWERTY UK
- Region
- United Kingdom, Ireland
- Palm Rest
- Numeric keypad
Pointing Device
- Mouse - wireless
- Pointing Device Name
- Logitech MX Master 3S for Business
- Buttons Qty
- 7
- Thumb Buttons Qty
- 2
- Movement Detection Technology
- Optical
- Movement Resolution
- 8000 dpi
- Batteries:
- Lithium polymer
- Orientation
- Right-handed
- Graphite
- Included Accessories
- Palm rest
- MTBF
- 150,000 hours
- Key Life Span
- 10 million clicks
- OS Required
- Linux, Google Chrome OS, Android 9.0 (Pie) or later, Apple iOS 14 or later, Apple iPadOS 14 or later, Windows 10 / 11 or later, Apple macOS 11 or later
- Rechargeable
- Technology
- Lithium polymer
- Run Time (Up To)
- 10 days
- Shipping Width
- 45.2 cm
- Shipping Depth
- 14.6 cm
- Shipping Height
- 7.5 cm
- Shipping Weight
- 1.56 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HFS8 048659 Condition: Customer return - item has been used and shows signs of use very slight in dent on mouse thumb rest where thumb nail has put an indent on item. |
£121.63 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
